anyone using boltdown batt terminals on their alternator?
what about fusing the amp then? same thing? fuse for wire? think biggest anl fuses are 300
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
They make 500amp anl
Fusing for the amp
Use a wire with a higher fuse rating or equal fuse rating as the manufacturer rates the amp at. Then fuse it at the amps fuses rating.
Example
A t1500.1bdcp has a fuse rating of 200amps. So I would use a wire that is rated at 200+ amps then put a 200amp fuse on it.
In my case with the 1500.1 ill be running ofc 0guage into it with a 0gauge to 4 gauge reducer. The wire is rated at 300amps. I'm still going to use a 200amp fuse to protect the amp though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
http://www.rockfordfosgate.com/products/details/rffa500
I'm sure other companies make fuses that go up to 500amps.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
dual input amp has 2 positive inputs so my question was which fuses to use on both wires if amp total draw is 500. once again electricity follow path of least resistance so 1 wire could be drawin more amps then the other (possibly)
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
No reason to fuse higher than your alts output and on your runs to the amp fuse for your current demand. The smaller the fuse the better.
Yeah we have a solution to this without using a battery terminal.
http://www.droppinhzcaraudio.com/toolmaker-quad-1-0-ring-terminal/
Also have Ceramic Fuses from 50-500A that are much better under the hood, as they resist heat MUCH better than cheap plastic cased fuses.
http://www.droppinhzcaraudio.com/ceramic-anl-fuse/
  • Who's Online   0 Members, 0 Anonymous, 1374 Guests (See full list)
