lost 2db. why?
I always heard of people upgrading their amps but only gaining a few tenths. Well I had a AQ 3500 v2 and got a audio systems 3k. Same exact thing as sundown saz 3k. Power wise, there's not much of a difference. I was dropping to 12.1v with the AQ and this amp I hardly see 12.9v
By ear, it sounds the same. I can't seem to tell a difference....well, I metered today.
With the AQ amp I did a 149.7 in the kick
New amp I did 147.2 in the kick...how da fuck did I loose so much? Does my peak change? Or did I just loose out all together?
Numbers don't matter to me so much but I feel heart broken after testing
You really can't figure it out?
could be crossed over to low.
plus if you test with subsonic filter off you can gain some.
the aq is probably adjusted a bit better than your sundown. Just keep tinkering with it.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
Box is solid man.
I don't see why a few hundred watts, let's say 1000w make a difference by 2db.
Not trying to sound dumb just wanna know more bout this
Double check your amp filters as already mentioned, its really easy to twist it all the way the wrong way, ask me how I know lol.
Otherwise, its always good to do a power clamp before swapping amps. Even if you can just see how much clean voltage the amp is able to supply it can give you an idea of how much power you are actually seeing.
Team NorthWestSPL
the hell is a audiosystems 3k, never even heard of them. aq is a good brand and audio system is most likely garbage if it doesnt even return a search result.
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
  • Who's Online   1 Member, 0 Anonymous, 4898 Guests (See full list)
