Is 300amp fuse ok for 220amp mechman alt?
Would a 300amp fuse work for a 220amp mechman alt? Or would a 250amp fuse be more ideal? I ask because I have a 300amp fuse already.
What wire is connected to that fuse?
Fuse to the specifications of that wire.
Will likely be CCA 0 gauge. I might get OFC though, not sure yet.
I think I see where you are going, if it is CCA 0 gauge then a 300amp fuse is useless as that wire cannot even handle that current.
300 amp is useless anyway.......
OP, what wire are you using, and where is connecting to/from?
Pretty sure I know where you're going with this, and it's where I was going. Lemme know if we're on par here.
Fuses will handle a significant amount more than they're rated for, for a given amount of time. Chart typically looks like this:
That's for a 100A ANL fuse. Notice how it will handle almost double its rated for a good amount of time?
For those that want more, here's a good starting point: http://www.bcae1.com/fuses.htm
Edit: geeeez that's hard to see. Sorry.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Fuse for your current demands, just because the alt is 220 amps doesn't mean you'll ever draw that much current.
I fuse for my wire :shrug:
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 4231 Guests (See full list)
