should i put the port on the side or the bottom both firing towards the trunk
zoeboi954
As AJ said, what does your electrical consist of?
97 Buick LeSabre with stock 140 amp alternator
XS Power D3400 (under the hood) using pdb distro blocks
Big 3 done with 2/0 ga welding cable
Alpine CDE-HD149BT head unit
CT Sounds Meso 6.5" components
CT Sounds 60.4
CT Sounds 1400.1
Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs)
Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders)
Connection BT2 & BT4 550 (Audison) RCA's
Bunch of Mojo Mat
Only way to know is to test all your options. There aren't many Prius builds around, so you'll have to do some work. That means multiple boxes.
You aren't planning on simply adding a port to the current box, are you?
SMD Super Seller
My Feedback Thread
I've never seen a system in a prius, hows your Electrical?
and aren't they hatch backs? with 4 12s i would port into the cabin.
http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/ thats a form of the prius i add another xs d2400. so now its 2 xs d2400 and and a yellow top. never had issue with electical, the battery stay full and the hybrd battery doesnt appear to be effected at all. its extremely loud for it to be in a sealed box. im going to hook up with the guy who made the box i'm using now for the new 1
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
running 4k in a prius is just awesome.
i guess it's like a normal car... how many amps is your alt?
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
thats the thing prius arent normal, dont have exposed belts and doesn't use an alternator, it uses a an inverter as a charging system from the hybrid battery to the 12v battery.and from what i read online some state the inverter give off 100 amps.
prius are really amazing how they work. hell it doesn't even shift gears
Hell, i may just sig that one...... and i dont even do that....
Ports along the bottom usually end up being very wide and not very tall. High aspect ratio ports like that aren't the most efficient things ever. It's certainly not a deal-breaker but it's something to consider.
Builds:
buys 4 Fi Q and says his going for SQ.. when you buy that many drivers SQ will be the last thing you will achieve.
well i used to own 2 Fi BTL 12s UFO mags in my 02 accord they were great. i loved them but i was wanted more SQ so i sold my BTLs and i bought 2 Fi Qs and i loved how the FI Q sound so much i bought 2 more. end up with 4 in a sealed box and right now every time i head out i get compliments on how good it sounds. and i been around enough spl system to hear a difference in sq compared to mines and thats just on 4k with spl kick
  • Who's Online   0 Members, 0 Anonymous, 989 Guests (See full list)
