Mechman Alternators
500amps at Idle, 900 amps peak power!!!!!
Got a couple of these getting ready to be in action this year in competition. Things are going to get real!
A couple ???!!! So, you have a "car" to run those beasts ?
I'd love to see that.
Congratulations
:good:
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
It's not that difficult to turn it over.
900amps= 900*15V=+- 13.5kW, about 15kW if you count in efficiency.
15kW=20.1Hp, it's only about 11.2HP at idle.
Just rev up the engine a little bit and youll be fine.
A BMW 320i already has 30+ HP at 1.5k rpm.
Does no one think the belt will have issues; really?
Do the math
1 hp is 550 lbs lifted up 1 meter (3.2ft) in 1 second
You think something that has 11 times that amount of drag will easily be turned.... Easy answer hell no... But let's get more reasoning
your turning something that is a rubber on metal friction connection which is held by the pressure of your belt tensioner most people with normal sized dual alts have massive belt slip so when you look at the actual surface area in the pulley it won't be enough to stop belt slip....... The surface area of 3 normal sized pullies is a lot more than one oversized pulley, therefore the three should slip much less than one
If people already have trouble with just three slipping how the hell are they going to make one not slip
And whoever said this is a custom application for under 2000 RPMs you are an idiot
Alternators spin at 2-3 times engine rpms just to make current so at idle
most are spinning 4000 to 6000 rpms just to make power AT IDLE
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
  • 1 month later...
anything on this??
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
  • Who's Online   0 Members, 0 Anonymous, 1411 Guests (See full list)
