Broke_Audio_Addict Posted August 15, 2015 Report Posted August 15, 2015 OK since I doubt you'll do an ls1 swap let's meet half way, gtp motor. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Deeznutz Posted August 15, 2015 Author Report Posted August 15, 2015 GTP? a 3800 Series lll supercharged? Christian already suggested it. Not sure since that's a front wheel drive transmission. May need to mod the rear(?) -Frank
Broke_Audio_Addict Posted August 15, 2015 Report Posted August 15, 2015 It'll bolt to your Trans no problem gm liked to keep bolt patterns them same. It's been done a couple times. And yes its a supercharged 3.8 with forged internals. http://www.fullthrottlev6.com/forums/showthread.php?30054-OMFG-it-actually-FITS That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
bighossf150 Posted August 15, 2015 Report Posted August 15, 2015 for what you would spend rebuilding the v6 you could buy a 5.3, harness and trans for damn near the same price http://houston.craigslist.org/pts/5134651964.html Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Deeznutz Posted May 15, 2016 Author Report Posted May 15, 2016 Update on the build. The motor is out. Had to remove the driver's side motor mount to wiggle it out. My neighbor helped me. My neighbor's engine stand. I stripped the motor. I found that cylinder 2's roller valve was FLAT!!! This led to metal in the motor. The bearing surfaces of the crank and cam took the brunt of it. I had more pics but I had to delete them since due to space on my phone. The rod and crank bearing halves had deep scratches in them but did not look to have egg'ed themselves out of shape. The rods bearing surfaces look great. The cam had moderate pitting on the lobe surfaces. Hard to see in the pic. The guy said that the irratic idle 950-1000 rpm could be caused by a valve not opening/closing properly and the engine compensated for it with the idle to keep the emissions proper. Makes sense. Block party time! I took care of a guy at work. On the way to ICU, I asked him what he did when he was in the work force just to distract him. Patients like that sort of thing. We chatted about the 3.8 I'm rebuilding. He told me "You really didn't have to drip it. A good degreaser and power sprayer can do the trick!". "Really?". "Son I was a mechanic for 40 yrs!". Ok he sold me on the idea. lol. I spent 1hr spraying her down with degreaser and a high powered nozzle. Good ol' Dex-cool sludge just kept pouring out. Took her to the shop and the shop guy said "motor's pretty clean and you want me to dip it?" "Can you get it clean...er and get rid of any sludge I couldn't reach?"......"yeah!" ...."than yeah dip it". There's a 3 wk backlog which is fine. The ZZP GT Cam I want to get is $324. The dipping, bearing replacement, honing, deglazing, etc will run me $248. Not bad. I will need new #105 springs to go with the new cam $324. A new re-man'ed crank $185, new roller lifters $90, new push rods $90, and new o.e. spec rockers $200'ish. Everything needs to be replaced due to the "low oil" condition the motor was in when I bought her worn EVERYTHING DOWN. What I want it to sound like....... -Frank
Broke_Audio_Addict Posted May 15, 2016 Report Posted May 15, 2016 Just put a v8 in it, not worth it to put money in that v6, it'll sound like shit and still be slow. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
boom50cal Posted May 15, 2016 Report Posted May 15, 2016 idk, the semi built v6 is a pretty neat idea. Would make for a cool daily. There's a dude in lawton with a turbo'ed 3800 with some just mild work, on radials...it's a nasty street monster. hang's with cammed ls3 5th gens and 5.0's all day. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Deeznutz Posted May 16, 2016 Author Report Posted May 16, 2016 Nah, shes going to be my daily like Boom said. -Frank
ShadeTreeMechanic Posted May 16, 2016 Report Posted May 16, 2016 Maybe a shot of nitrous to surprise people. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bighossf150 Posted May 16, 2016 Report Posted May 16, 2016 lmfao, I daily a heads/cam forged 347 ls1 car and it drives exactly like a bolt on car Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
