^^says a Tahoe.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Tune to Hairtrick Hz. Do a low tuned ported(which IS a 4th order by the way).
I meant regular ported box lol.
Yeah, that's what I was referring to. A regular ported box IS a 4th order.
Jesus, with that much space for just 2 15s, you could play around with a 6th order or large ratio 4th order (both bp). It all comes down to what response you're looking for. If I was you, I'd go at least 3.5:1 ratio, with lots of port area. You'll have to get with a box designer to confirm which is best and what would be good for your specific drivers T/s.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
i have a design for a 4th order for 2 sa15s, and its almost 19 cubes. i think he would need more than 14 and is that 14 gross or 14 net
Post in the correct section
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
