1 run of 1/0 or 2
Are you saying I'm wrong by using larger, better grade cable than multiple smaller cables ???
Cause that's all I've suggested ...
No one thing I forgot to add is I've always used "high voltage" amplifiers and not "high current" amplifiers. That could be a determining factor there ...
You said a single run of 2 Guage instead of 2 runs of 1/0.
Which ones bigger?
Because I could swear 1/0 is bigger than 2 guage.
Right but you should always wire for what your system has the maximum potential to draw not less than and assume oh well it will never pull that much anyways.
I would agree if you were saying use smaller fuses which is what I would do personally but not smaller wire.
Sorry but you guys are both wrong.
Ok, so using the method you suggested, I would still be correct. I said two runs. So, either you didn't understand what I said or you didn't really read what I said.
Cars are a fairly simple circuit in terms of what size wire/fusing to use where when strictly talking alt/batteries/amps. If you lay it out, it's not hard to see where you will get what kind of draw. There's quite a few different possibilites.
I've seen some 1/0 CCA that's smaller than 4 Guage so the brand matters you can't just say 2 runs is fine.
Which ones bigger?
he was asked what he meant and said he meant 2/0 gauge... helps if you read everything before going on a rant
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Which ones bigger?
The post was edited to ask him what he meant after I responded
Which ones bigger?
I edited at 1216, he responded at 1217, you replied at 1226. Backpedal much?
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Is it unrealistic to believe that I was typing it already and hadn't hit submit or refreshed the page to see that?
Because that's exactly what happened.
either way 2 runs of 1/0 is greater than one run of 2/0 if both are the same brand and type of wire.
he already has the wire as well it wouldn't be my choice in wire but he has it already so why not use it?
True, but Cablguy's answer is better. Bigger wire = Less Runs = Less wiring hassle for essentially the same results in this application.
So what about the negative run from front to back batteries is it worth doing for just that amount of power? And also is the advice you guys are giving me saying to just go ahead and use the 2 runs of audiopipe 1/0 power to the back? Like i say i have 1 kinetik 2000 up front and 1 in the back. To be honest i wish i could put them both up front but idk if that would hurt my voltage in the back
  • Who's Online   0 Members, 0 Anonymous, 1077 Guests (See full list)
