Recommended Mids/Highs Amplifier
jazzie366
Well, my Pioneer that's rated 150W @ 4 ohms isn't powerful enough. Bass overtakes the mids at any volume. Bass amp doesn't even get hot either, if anything I can turn it way the hell up.
Had the bass higher before, still didn't even get warm.
But yeah, I don't know what to use and I know JL Audio makes a 500W two channel amp for this kind of application, but I'm a poor little schoolboy so I can't afford it.
In my beginning post, I found a Hifonics amp that's rated 500W max, but only 160RMS.
If your running all your amps at 4 ohm, since your so infatuated with the 4 ohm rating i assume you must be, then of course they're never going to get hot, they're most likely designed to run stereo 2 ohm loads, like i said before the gain IS NOT A VOLUME NOB, turning it up is only going to increase the amount of clipping the amp produces, it still cant create power so it has limitations that it cannot pass in terms of output voltage, your just getting closer to a square sine wave, therefore just working the speakers more, not the amplifier. If your pioneer is a 4-channel, maybe try bridging it and running your speakers in parallel so youll get "more power", and still be at a 4 ohm load if possible.
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
You are describing a T15k
http://www.rockfordfosgate.com/products/details/t15kw
Good luck
It doesn't have enough capacitors.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Lmfao haters what are we hating on your lack of knowledge? People actually telling you what your doing wrong and you still ignoring it
Or the fact that anybody that knows anything about audio knows your talking out your ass while asking advice at the same time acting like you know it all
Here is an idea you won't do but will take you far on this forum
Admit you have no clue what your doing and humbly ask what could be wrong with your system cause you have problems and an amp ain't one of them
Then when someone with a lot more knowledge gives you some good info don't try to act like you know what your are talking about and tell them there wrong because of some caps and transistors oh and some bs cea-2006 certification
Then you will get tons of help
Unfortunately your ego (I have no idea why you have one) will prevent you from doing this and we are just a bunch of haters
I can't stand this thread anymore and won't allow it to continue anymore.
I'm locking this down like Guantanamo Bay.
  • Who's Online   1 Member, 0 Anonymous, 1520 Guests (See full list)
