JL Audio 1000/1 v1 amp melting wires problem
Flip_one
Get rid of that 300 amp fuse too and get one much smaller, I'd start with a 100 amp.
Each wire should have its own fuse as well not a shared fuse.
What is that extra ground wire connected at the amp for? That little wire melted the tape. There really is no reason for 0g wire in that amp, save your self some trouble and get some 4g wire and use it. Especially that close to the battery which is connected to the front battery with 0g. Like someone else said as well, get a separate fuse for each wire.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Also you really should run a turn on relay for those remote wires
I've had 4ga wire from the second battery to the amp before but it was worse, at first the power 4ga wire will burn up so I took it out and put 0ga then the ground 4ga burned up so I also put 0ga... With the 0ga power and ground wires works just fine for about 2 months then when I turn it up loud thats when the 0ga ground starts to melt. Other than that the amp works perfect.
That guy is an idiot, there is something wrong with the amp or the install.
I'd suggest finding a new shop that actually knows what they are doing.
Agree, I'm thinking there is more chance that there is something wrong in the install then the amp.
You are shorting out somewhere after the fuse.
  • Who's Online   0 Members, 0 Anonymous, 1616 Guests (See full list)
