1/4" straight bit, and my jasper jig.
Edit: with a little sanding to open it up some because the jig is .xxxx too small, but the next size up is .xxxx too big.
Edited by reedal
And then there were two
91209E7B-7978-4437-8D88-0BFED197FC38_zps
Sanded down the outer edges to clean up the roughness and make them exactly the same size.
15E1601D-01FF-4D76-9C31-2DB9ADCC145C_zps
Unfortunately, dremel battery is dead, so once it's charged up I'll sand the inner rings/edges smooth and be able to fit the speakers in.
It'll all look pretty when I'm done.
It's easy to make that flush ring with the right bit.
What bit would be better to use? I only have a few, but I'm always willing to add more. Would the bit make up for the fact that I do not have the correct size for these speakers available on my jig?
You'd need a different bit. Even a Harbor Freight cheapie set would do the trick.
A different straight bit? Or a different kind of bit as a whole? I have a 3/8 straight as well...
Cut out the mounting rings for the L8's.
A4A11B30-34FF-4172-BFB9-DCF2C75FFEEA_zps
Got started on the rings for the L6's and ended up snapping the bit. I suppose my next bit will be from MS or 12vtools since that seems to be the best choices from what I've read on here.
Edited by reedal
  • Who's Online   0 Members, 0 Anonymous, 1212 Guests (See full list)
