Subs cutting in and out.
I don't know where ya'll are getting 4 amps from but he said he has 4 subs, and then says one pair is fine and the other is acting up. So if he's got four subs and saying there wired to one ohm per pair, then it looks to me like he's got 4 D4 subs on two amps.
Because he wrote:
I'm running 4 subs each on separate amps
Makes me think he had 4 amps.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
but then he talked about setting the gains on both amps. So maybe op just needs to give us a list of what he's working with to verify all of this.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
So what joe said still works, find out what is common between the 2 failing amps that is different than the other two amps.
That's what I tried at first. But I cannot find any difference. Both Amps are putting out 42.3 volts,and every connection is secure. I'm going to swap the Subs and amp and see if the problem continues on the same side; if it does continue then it's my subs. If it stops and transfers to the opposite side then it's my amp. Im not exactly sure what It would be on the amp causing this proble tho.
Who knows what it is but is not a good idea to mount amps directly on the box.
I'm going to try and stack some more rubber under the amp mounts on each one. Its possible that vibration killed it
2014 JKU
Sound:
pioneer xav-65
4 12in pioneer tsw3003d4
2 pioneer gm-d9601
(much more in route)
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
The Build Log: http://www.stevemeadedesigns.com/board/topic/195839-2014-jku-build-4-12s/
If you haven't yet.check the connections on the subs. My brother was having that issue and thought he needed bet yer grounds.. Checked the connections and one was lose causing amp to not send signal or going to protect
Grounding was also what I thought at first,but ground is good and so aren't my connections. Thanks for the suggestion
2014 JKU
Sound:
pioneer xav-65
2 pioneer gm-d9601
General:
18in worx rims
33in tire
stinger src bumpers
light bars
6k hids
2in leveling kit
3.25in lift
  • Who's Online   0 Members, 0 Anonymous, 3026 Guests (See full list)
