RF T1500-1BDCP Fusing question
Ok, I we have the RF T1500-1BDCP installed in the Jimmy pushing 4 RF HX2 12's (The RF Power 15's recone and install are on hold til I fix the Camaro). There 's a 200 Amp Sound Quest fuse up front by the battery.
Reading the manual, the amp does call for a 200 Amp fuse to be connected between the amp and battery.
In the past I've only installed amps with on-board fuses- using the same battery-fuse concept.
Not too familiar with the non-fused amps thus the question.
Do I have to fuse the amp again with a 200 Amp fuse, and upgrade the battery fuse to a 300 amp fuse now that the
T1500 is connected-AND- it's still a 2 amp system?
The 200 Amp at the battery was for the Avionixx amps, combined fuses totaled 200 amps (30Ax4, and 40Ax2).
Please school on this stuff regarding non-fused amps.
Appreciate the feedback.
-Frank
Youve upped your draw. I'd put in a 300 amp fuse. Since you now have two amps how are you distributing the wire to each amp? I typically fuse a distribution block and fuse each amp there
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I have 0 gauge stinger at the battery/fuse junction to the back of the Jimmy.
From the back, I have the 0 gauge on a wooden block with a bolt, a 4 gauge wire feeds the T1500-1, and an 8 gauge feeds the Avionixx 4 channel. (Using only 2 channels)
So 300A ANF at the battery, than a dual ANF or Maxi-fuse distribution block with an 80A and 200A to feed both amps?
I appreciate the feedback N8!
-Frank
cool, I had an extra 200A fuse and block, but I thought "if there's 2 200A fuses in series, will one blow if the amp needs it to in order to protect it?". If that's the way to do it, than I will do it. Larger fuse, to smaller fuses.
Thx guys.
-Frank
so you have 2 amplifiers right? one that has 120 amps of fusing on it and one that has none, but requires 200 amps?
if so, I would drop a 300 amp fuse on your 0g near the battery then run that wire to a distro block. Then from there, use a 200amp for the RF and a 120amp for the other amplifier.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
LOL. The current set up is:
200A fuse at the battery
Avionixx CXA1040 with 40A x 2 fuses
RF T1500-1BDCP requiring a 200A fuse.
All these amps and numbers can be confusing. lol.
-Frank
You can't supply that much current anyways so fuse it for what you an supply.
That being said I could feed mine and it played music with a 120 amp fuse.
Rockford list the average current draw as 100 amps on music.
  • Who's Online   0 Members, 0 Anonymous, 3413 Guests (See full list)
