im wondering if polyfill would actually make a difference on an sa 15 in a ported 3 cu box. ive heard that it makes lows hit better but idk how a bunch of cotton would hold up inside a box with an sa15. wouldnt it get sucked in around the spiders and maybe even in where the coils are and cause it to overhear? any input would be great
Only effects sealed enclosures. Go ahead and throw some ported box and upload the video so we can have some luls. But for real, sealed only.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • 3 weeks later...
^ This.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
Not true. It can have a profound effect on vented enclosures as well.
You just have to chicken wire the throat of the port or a similar method of keeping the shit in there. Because I can tell you from experience that it comes out IN A HURRY. Lol
As other have said, polyfill (it's not cotton, don't use cotton) will only hurt your output with a ported box.
Builds:
Use a poly batting instead of polyfill to achieve the same performance without the effects of tricking the sub acting as if it is in a larger enclosure.
They come in a 1" thickness and line 3 walls with it, it will make the enclosure have a deeper richer sound to it.
http://www.ebay.com/itm/Bonded-Dacron-Upholstery-Grade-Polyester-Batting-48-Inch-Wide-Sold-By-The-Yard-/151702528895?pt=LH_DefaultDomain_0&hash=item23522ce37f
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Good answer right here (and yours TFade, as always). As Skullz said, you'd want to use the actual batting vs the loose stuff. It can DEFINITELY affect and improve the sound of some ported enclosures for sure. Most here have never tried it and don't have experience other than sealed applications. To get the batting to stick, you can glue and staple of you'd like.
  • 7 months later...
Have a GMC crew cab with 2 12" kicker CompRTs in a down fire box. I spoke with a Kicker rep because I've read that the 500 RMS rating is under rated by the company and more like around 700. He also suggested to polyfill about half the box which is .87 cu ft. I've been reading that people just stuff it into the box, but I feel that would turn out not so well with my subs facing down. I've seen on YouTube about using spray adhesive to line the walls but wondering if layering sheets of this stuff with minimal glue is a feasable option. Any help/tip.
Thinking about also ditching kickers for some RE SCX 12's.
Providing the box is sealed you'll be fine just placing it in the box, and the subs bottom will keep the polyfill from coming up into the sub.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
