rmireles1 Posted August 13, 2015 Report Posted August 13, 2015 Hi Everyone, Really need help and the recommendations/suggestions of you more experienced folks. I recently purchased a Crescendo BC5500 amp to power my (4) subs. I have them in a 4th order tuned in the high 20s. Since subs are dual 1 ohm, i currently have a 0.5 ohm load on my amp. Here is list of my equipment and a quick diagram of how i have it connected (excuse the crappy pic). Sounds great but my amps heats up FAST then goes into protect mode. Won't turn on till 30+mins after it cools down. I reached out to Crescendo and they confirmed my amp model has an internal fan (even though i can't hear or feel it) and suggested my wiring was wrong after we went back and forth on what my system consists off. List of equipment on my 98 (2) door Chevy Tahoe Front of truck (1) Yellow Top Optima (1) Iraggi Alt 240amp low idle (1) DC Power Alt 240amp rebuilt by Iraggi (2) aftermarket electric fans Rear of truck (4) 15 in. RE Audio SXX w/ PSI recones (1) Crescendo Amp BC5500d (1) Boss Audio amp D350.4 (mids/highs) (2) XS Power D5100 (2) XS Power D925 All +/- wiring is SHCA 0 gauge with the exception of the ones going to the Boss amp and coming from the electric fans. I know my wiring ain't ideal or perfect, but before i "re-wire" it again, i want to do it right. Any recommendations??
matt14 Posted August 13, 2015 Report Posted August 13, 2015 Have you measured voltage at the amp with a multimeter when it cuts out? Clipping it too much? 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
rmireles1 Posted August 13, 2015 Author Report Posted August 13, 2015 Have you measured voltage at the amp with a multimeter when it cuts out? Clipping it too much? I have a digital volt meter but have it connected at front alts. Voltage there is steady at around 13.8-14.0 volts. I would have to connect the multimeter and stare at it until it turns off. Is that what I should do? Regarding the clipping, not sure how to check that with a multimeter.
Dan2427 Posted August 13, 2015 Report Posted August 13, 2015 Why is your fourth order tuned in the 20s? I would DMM all coils separately if voltage is fine 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
Kyblack76 Posted August 13, 2015 Report Posted August 13, 2015 Impedance SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Kyblack76 Posted August 13, 2015 Report Posted August 13, 2015 You had your DC alt rebuilt by Dom ? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
matt14 Posted August 13, 2015 Report Posted August 13, 2015 Does it cut off full tilt? 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Broke_Audio_Addict Posted August 13, 2015 Report Posted August 13, 2015 You had your DC alt rebuilt by Dom ? This. wtf? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
rmireles1 Posted August 13, 2015 Author Report Posted August 13, 2015 Why is your fourth order tuned in the 20s? I would DMM all coils separately if voltage is fine Sorry, meant that my 4th hits in the high 20hz range. Not sure wut the port is tuned at. Ur saying to confirm all voice coils are 1 ohm?
rmireles1 Posted August 13, 2015 Author Report Posted August 13, 2015 You had your DC alt rebuilt by Dom ? Yes, by Dom at Iraggi. Is that bad?
