torres areo port help
jlmtx2002
In the torres program when you use multiple round ports, does the length of the port need to be divided over the number of ports? Ex(2 4" ports 10" long) Does each port need to be 10" long or 5"?
Also, when you double the number of ports (go to two 4" ports instead of one) they each have to be twice as long (roughly) to keep the same tuning.
Builds:
Torres unfortunately miscalculates the ports length for multiple aeros, if you are using PSP ports you can still use their online calculator to get the correct ports length.
Well maybe I should have made this i enclosure design help instead of a Torres area port question. Let's start at the top. I have been given a DB Drive plw12d4. I am putting it in a 02 camero. I have an angle enclosure measuring, 11.5x25.5 bottom. 15x25.5 height. 13.75x25.5 top baffle. Sub up and port up. Roughly 2.1cube according to Torres. I realize I can't tune crazy low in that small of space without making port crazy long. I am going to be using some type of areo port. How many and what size and length is what I'm working on now. Any advise would be greatly appriciated.
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
