Mechman Alternators
Then run duals or trips of the 370s that big thing has no output at idle. And that engine idles and runs low as hell to begin with
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Potential current draw and actual are not the same thing.
A true 8k rms rated amp isn't very likely to actually ever put out 8k rms in a car on music.
N8 runs dual 370's on 20k.
and what's your voltage drop again n8?
Depends on how long a period of time we are talking about. I'd benefit from a. Third but I'm not in danger territory either
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
drawling 8000wrms no
lol
youd be fine with a 320 and some bats....
sure if i want voltage issues that would work
No no no. Kyle ran 10k off a a single 350. I think ninja is running 2 8ks off of a single alt. Kevin runs 4 ns1s off of 2 370s. You are thinking to much about it.
why is everything on this forum a conistant fight? i notice this in ALOT of threads n8ball is the only person here which helpful thank you nate for trying to be helpful
its 2 b2 zeros running bridged at 1 ohm and a gladen 250.4 at 2 ohms per channel.. at a half ohm each the b2s are more than likely going to be less than 80% efficent producing over 9000 k betweent eh pair drawling 11250 watts and 2200 + watt draw from the highs amp so an rms drawl of 13450 /14.4 volts thats 934 amps. Factor in most alts companies including mechman recommend 70-80 % of your current drawl in charging power thats 650-750 ish amps factor in peaks and vallies in music and you have about a 450-500 amp drawl
Edited by nocturnalrites101
At .5 ohm they are probably 50% efficient if you're lucky.
Edited by Broke_Audio_Addict
  • Who's Online   1 Member, 0 Anonymous, 1168 Guests (See full list)
