Rear loading in an extended cab Chevy truck
Hotdog
Has anyone ever rear loaded in a Chevy extended cab truck. Friend of mine said his sound loudest when the subs are facing the back wall about 8" away. He had asked if I could build him a box for to Rockfod Fosgate RFR1815 subs for his truck. I though since he liked the rear loaded configuration that I would design the box that way.
here is what I have put together so far. The is for a 1994 Chevy extended cab pick up with rear seats removed. The open area to the left side bottom will go over the tire jack box.
Rich%201994%20Chevy%20truck%20Box%201_zp
Though that a piece of MDF mounted to the back could be used to load off of. Otherwise I agree with you it is a weak point
It is definitely weak in my 02 not sure if the 94 is the same.
Ports in the picture look pretty small.
Builds:
two 4" Ports 5.25" long. That is All that is required for the old school Rockford RFR1815. They dont have much xmax 0.244in
I disagree, I don't think that's anywhere near enough port area, but it going to be dependant on how much power you are going to be putting to them.
Builds:
He is powering them with a Kicker SX900.2. It is currently hooked up in the original Rockford Fosgate sealed enclosure.
http://www.sonicelectronix.com/pictures_new.php?id=3591&picture_id=-1
On that amount of power I'd use three 4" ports and you should be fine.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 6716 Guests (See full list)
