anyone use feurrules? pros and cons
Forgive me if this has been talked about before, as I couldn't find any other threads about these. Looking in to using 1/0 ferrules on my wire ends. They will be crimped hydraulic. The wires that go directly in to the fuse boxes and directly in to the amp inputs. Anyone else do this? Pros? Cons?
http://www.ebay.com/itm/261644858209?_trksid=p2060353.m1438.12649&ssPageName=STRK%3AMEBIDX%3AIT
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
They look like they would do a great job, and make everything look nice and neat. I'm just cautious on fitting. I use Knu wire, so it should fit. Then crimp, and done. Maybe even some heat shrink wrap just flush with it to look nice. Anyone have any other online places to purchase them...copper would be sick...just don't know pricing.
Singer 220 amp alt
we just started using them and they are fanfuckingtastic work with sky high wire and dc amps well the ones we ordered do. dont need to get an input from tool maker or sky high and it contains all strands and gives you tons of contact inside the amp terminal
i use them to connect my direct leads to 8 gauge speaker wire for my subs, got the idea from AMI customs (the black nasty). they definitely work very well
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
11855765_10204562177834157_7007196397486
moar pics of car?
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
If you want copper, check the electrical isle at Home Depot or Lowes. I don't think you'll get them in anything larger than 8ga though. Might be able to jam 4ga in there, but I haven't tried. I used the larger ones to fit two 8ga SHCA cables in for my subs and they fit just fine. SO maybe 4ga would go. But they're stout and copper. I was thinking of doing this for my next build as well. Just because of that picture Will just posted. Very clean, very tidy and easy to install into the amp without the worry of stray strands.
will, you just used a hydraulic crimper? or did you solder? those pics look great! exactly what I had in mind! and I'll check out Home Depot and Lowes.
Singer 220 amp alt
  • Who's Online   0 Members, 0 Anonymous, 694 Guests (See full list)
