Why aren't my subs loud
Lsufan51
I have 2 fosgate t1 dvc 4 ohm 12s on a fosgate t2500bdcp. They are wired to a 4 ohm load so they should be getting just about the right amount of power. The amp was tuned with a dd1. The problem is they don't get loud until I crank the volume up to about 3/4 of the way. The box they are in is built to specs. Why aren't they getting loud?
If I change the ohm load, would I need to tune my amp again?
If it was tuned with a dd1 then no
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
There is nothing wrong with it. In fact, that's how it should be when an amp is tuned right. When your system gets loud on number 10 it means the gain is turned way up. When it's tuned right you get max at head unit max. If you wire to 1 ohm you will have same result but will be loud due to more power. If you wire at 1 ohm I would retune it due to the fact that it draws more amperage and can cause it to clip sooner
Why does it matter the point at which you start to hear them? If it's that big of a deal, set your gain with volume at that halfway point. And then don't go past it. I don't understand the point of this thread, or the 6 others you made about the same issue within twenty minutes
  • Who's Online   1 Member, 0 Anonymous, 800 Guests (See full list)
