2004 'burban. 2 DC Lv6m2's, 9kw $5500 budget build
It can't hurt to run the caps. If I had them I wouldn't hesitate to run them. If anything it will help stiffen the voltage up a little bit.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Well the issue i'm having is the amps have dual power/ground inputs and the caps only have one, so if i ran them i would have to run a single run from the battery to the cap, then run a 1 1/0-to-2 1/0 distribution block between the cap and amp. Would that even be safe to do?
You can get terminals made to allow the caps to accept dual inputs if you want, but to answer your question it will be fine to run the way that you asked about.
1 XS Power D3100
Audio Control LC6i
Stock Deck
Oh... well in that case i may just do that, i'll be running the caps right next to the amps so it'll only be 10" of cable between batt/cap and cap/amp.
tuned in!
01 Suburban Z71 - 5.3L - Black - 6" Lift on 35's - Pioneer H/U - Kicker Mids, 8" Polk sub.
Past rides-
07 Avalanche - Sunburst Orange - 4/6 Drop - Pioneer AVH-X5600 - 2/0 Royal Excelene - T/M fuse blocks - Stock and Singer 350 Alts - 4 Kinetik 1800 - Crecsendo BC5500 & S800.4 amps - 2 Tantric HDD 18's.- RE XXX 6.5 comps
01 Grand Vitara - V6 - 4x4 - Pioneer H/U - Incriminator 6.5 Comps - SSA XCON 18 - Skar 1500.1 & 84.4 amps - Singer 160 Alternator - Optima Yellow top..
Since this is a budget build (mine was originally as well) I would have recommended some Dekas over the Xs Power batts, then you may have been able to snag another one or two. I have a Mechman 370 and it is a TANK... One more thing, I think I would go with some 1/0 Welding cable over the 1/0 CCA. In my budget build I was able to locate some reasonably priced OFC welding cable and never looked back. Box looks dope man !
Kenwood KVT-614
(4) Marathon 155 AH batts
2/0 OFC SHCA
Mechman 370
(2) Audioque 3500.1
(2) AA Mayhem 15s
Sorry i haven't been on in a couple days, my day off didn't feel like a day off at all. I'll be pushing to get the box built and sealed up tonight. Thanks for all the support and input guys, it really helps motivate me to get it done and bangin' :slayer:
