ToNasty Posted October 16, 2015 Report Posted October 16, 2015 I'd like to see. You an me have basically the same underhood except your main batt and secondary batt are opposites ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Clownrock95 Posted October 17, 2015 Report Posted October 17, 2015 Is it bad I'm planning out the audio system prior to even buying the car.......... I've seen people catch flack for it before (helpful flack but flack)
ChevyBoy95 Posted October 17, 2015 Report Posted October 17, 2015 stock size AGM and 3 group 31's, maybe 4 for 6k on 1 alt IMO. I had 3 D3100's, 1 S3400, and a 200a alt and 7k on bass and still hit low 12's. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
diegoclass2010 Posted October 17, 2015 Report Posted October 17, 2015 I mean I can fit a d3400 or a d3100 under my hood as an example. I'm curious to know how you can fit a 3100 because it's a lot bigger than a 3400 i fitted a D3100 on my car....
diegoclass2010 Posted October 17, 2015 Report Posted October 17, 2015 op X2 what chevyboys said... you might get away with 2 xp3000 in the back and one agm battery in the front... but your probably gonna have short demos at full tilt, that is if you dont mind mind playing below 12volts you might also have to charge your batterys more often
Karkov Posted October 17, 2015 Report Posted October 17, 2015 I'd like to see. You an me have basically the same underhood except your main batt and secondary batt are opposites I will find the pics in my log in on my PC and PM you. EDIT: when I'm not at work....... 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
Lakeshow94 Posted October 18, 2015 Author Report Posted October 18, 2015 I'll keep that in mind. I hit up singer and he said he can do a 320 amp direct bolt on so that helps a bit. I'm gonna start with a xs d 2400 underhood if I can fit it with 2 xp 3000. I guess just add batteries after that until I am happy with voltage (assuming everything else is done correctly). for 6500 will 2 runs of 1/0 be enough? 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
Lakeshow94 Posted October 18, 2015 Author Report Posted October 18, 2015 Also is there a reason why on droppin hz it recommends 2-3 xs d3100 in the rear (for a dc 5k) vs 2-3 xp 3000? I was of the understanding if the battery isn't going to be under the hood (reserve bank) the xp series is just as good as the d series just cheaper. 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
diegoclass2010 Posted October 18, 2015 Report Posted October 18, 2015 yup its been proven when you need battery reserve power xp serious is the way to go over D serious
Lakeshow94 Posted October 18, 2015 Author Report Posted October 18, 2015 yup its been proven when you need battery reserve power xp serious is the way to go over D serious That's what I thought. Droppin hz must have it backwards. They "recommend" 2-3 d3100's in reserve................ 1999 Lexus GS 300 Pioneer DEH-80PRS Singer 240 Amp (Will be installed later) Northstar Group 31 & 24 Sundown SCV-4000 Rockford T400-4 2 12" CT Sound Meso CT Sounds 6.5 Meso Components CT Sounds Tropo 6.5
