Methodic Menace Posted December 1, 2015 Report Posted December 1, 2015 Current set up Rockford Fosgate P500.2 bridged 2 12" Kenwood Excelon KFC-XW12 Sealed box. Thinking about the following Rockford Fosgate P500.2 bridged 12" Kenwood Excelon KFC-XW12 Ported / Vented Box Thoughts, Suggestions? Vehicle is a 2010 Ford E350 and the subs are allllll the way in the rear of the van facing up at the moment. TDH Methodic Menace ?
mcfalcon Posted December 1, 2015 Report Posted December 1, 2015 I mean nothing would be changing except the enclosure. A properly designed and ported box would probably sound better but it all depends on what you like. What are your goals in changing the design? Still learning but have started gathering.
Smoove Posted December 1, 2015 Report Posted December 1, 2015 do ported at like 36hz and set you subsonic/infrasonic filter arond 30. then be done 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Methodic Menace Posted December 1, 2015 Author Report Posted December 1, 2015 Wanting to sound louder to be honest. I'm only going to get so loud with the amp. So budget in mind TDH Methodic Menace ?
Methodic Menace Posted December 1, 2015 Author Report Posted December 1, 2015 No subsonic on amp TDH Methodic Menace ?
3vil Posted December 1, 2015 Report Posted December 1, 2015 Am I misreading your first post, or are you wanting to remove one sub? I'm guessing it's to push more power to the remaining sub? Why not build the ported box for both 12's, then save a little cash to buy a larger amp? Maybe I'm totally misinterpreting what you're trying to do here.
Triticum Agricolam Posted December 1, 2015 Report Posted December 1, 2015 I worked with those Kenwood subs before, unfortunately I don't really have anything good to say about them. Their QTS is much too high, and EBP is much too low for them to ever work well in a ported box. No matter where you tune the box, you are going to get a big peak in output around 50 hz. They are happy in a sealed box and that is where I would leave them. If you want to get louder, save your money and buy some different subs that will work well in a ported box and are appropriate for the power you are running. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
crispy_chick3n Posted December 1, 2015 Report Posted December 1, 2015 I worked with those Kenwood subs before, unfortunately I don't really have anything good to say about them. Their QTS is much too high, and EBP is much too low for them to ever work well in a ported box. No matter where you tune the box, you are going to get a big peak in output around 50 hz. They are happy in a sealed box and that is where I would leave them. If you want to get louder, save your money and buy some different subs that will work well in a ported box and are appropriate for the power you are running. ^^^^this x100 This page is crispy_chick3n approved. © crispy_chick3n inc
