ShadeTreeMechanic Posted January 7, 2016 Report Share Posted January 7, 2016 How about a big M-4 gut shot to keep this going? The transistors are small but there are a bunch of them. Here is the link to my post. http://www.stevemeadedesigns.com/board/topic/202601-rockville-m-4-at-5-ohm-no-joke/ (sorry i couldn't resist) 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 7, 2016 Report Share Posted January 7, 2016 I almost bought the AP1500 but got the M-4 instead.So bought same amp with different name? So does the name make it better?I had the budget amps before. I used to say for $270 it does okay. I was happy, but then I bought a DC audio amp and the difference is nigh and day. Just the sound it produces makes a lot of difference. With cheap amps you get loud somewhat but sound like shit. I like to hear good music not shit music. once you test better amps you will see how wrong you are. I can care less what anyone runs. It's their money and maybe it's all they can afford so I won't judge foe that reason but don't try to compare amps. Quality amps cost more for a reason. The better they are the more they cost. You can get a very good amp that cost $2500 and only put bout 1500 watts but it sounds amazing. That $150 amp might get louder but sounds like crap I only turn it up until the crap comes out then i back it off a little LOL!! 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 7, 2016 Report Share Posted January 7, 2016 Anyone have a gut shot of an AP1500 they can throw up here? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
BoomZoom808 Posted January 7, 2016 Report Share Posted January 7, 2016 How about a big M-4 gut shot to keep this going? The transistors are small but there are a bunch of them. (sorry i couldn't resist) RMS Power Ratings: (Use these RMS ratings when comparing with great brands such as Hifonics, Earthquake, Soundstream, etc) 1 Ohm: 3000 Watts x 1 Channel 2 Ohm: 2000 Watts x 1 Channel 4 Ohm: 1500 Watts x 1 Channel Soundsstream 2K guts hmmmm 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
n8ball2013 Posted January 7, 2016 Report Share Posted January 7, 2016 Orion 2500d THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 7, 2016 Report Share Posted January 7, 2016 How about a big M-4 gut shot to keep this going? The transistors are small but there are a bunch of them. (sorry i couldn't resist) RMS Power Ratings: (Use these RMS ratings when comparing with great brands such as Hifonics, Earthquake, Soundstream, etc) 1 Ohm: 3000 Watts x 1 Channel 2 Ohm: 2000 Watts x 1 Channel 4 Ohm: 1500 Watts x 1 Channel Soundsstream 2K guts hmmmm Thanks! so the AP1500 has more caps and less transistors. The final stage transistors are big and what i would expect to see. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
BoomZoom808 Posted January 7, 2016 Report Share Posted January 7, 2016 That's a soundstream here is the audiopipe http://www.stevemeadedesigns.com/board/topic/77108-audio-pipe-ap-15001d-guts/ 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 7, 2016 Report Share Posted January 7, 2016 Orion 2500d Is this an old school amp? AB or D? Big fat coils and tons of caps! So how much does this monster cost? (Sorry i will quit jacking the thread so much) 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
n8ball2013 Posted January 7, 2016 Report Share Posted January 7, 2016 It's a class d. It's an earlier class d though. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
mcfalcon Posted January 7, 2016 Report Share Posted January 7, 2016 How about a big M-4 gut shot to keep this going? The transistors are small but there are a bunch of them.(sorry i couldn't resist) RMS Power Ratings: (Use these RMS ratings when comparing with great brands such as Hifonics, Earthquake, Soundstream, etc)1 Ohm: 3000 Watts x 1 Channel2 Ohm: 2000 Watts x 1 Channel4 Ohm: 1500 Watts x 1 Channel Soundsstream 2K guts hmmmm And it's really a 1500 watt amp which doesn't do rated. More like 1200 watt. Why can't yall get it through your heads? We all know they lied. We all know it's not top quality. But yet you want to throw out gut shots of decent amps to try to compare it to. Nobody is saying this will compare with a sundown or rockford or dc. Still learning but have started gathering. Link to comment Share on other sites More sharing options...
