Hugh G. Rection Posted December 29, 2015 Author Report Posted December 29, 2015 Ill tell you guys what, ill do a couple of vids this weekend on a build im doing. Itll most likely be a 1/4 wave tapered transmission line enclosure, and itll be for 3 skar ix subs on a sk800.1 in an expedition. I tested one of the ix 12s this past weekend in a tapered line on less than 400rms and got it to a 140.1 on the termlab, in the rear seat area of a 4 door nissan titan. Frequency response was stellar as all frequencies between 38hz and 65hz were all within 2db. Owner of BigAss Ports
firebirdude Posted December 29, 2015 Report Posted December 29, 2015 Maybe covering the enclosure? Carpet and vinyl?
reedal Posted December 29, 2015 Report Posted December 29, 2015 Sweet. Thank you. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
miniSPLlancer Posted December 29, 2015 Report Posted December 29, 2015 Just finished my T-Line for an 8". Tuned in 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
Broke_Audio_Addict Posted December 29, 2015 Report Posted December 29, 2015 Looking forward too it. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Hugh G. Rection Posted December 29, 2015 Author Report Posted December 29, 2015 Maybe covering the enclosure? Carpet and vinyl? I prefer to stick to the construction and optimization apects of enclosures, as my work always focuses on performance over glamour. Owner of BigAss Ports
Triticum Agricolam Posted December 29, 2015 Report Posted December 29, 2015 Ill tell you guys what, ill do a couple of vids this weekend on a build im doing. Itll most likely be a 1/4 wave tapered transmission line enclosure, and itll be for 3 skar ix subs on a sk800.1 in an expedition. I tested one of the ix 12s this past weekend in a tapered line on less than 400rms and got it to a 140.1 on the termlab, in the rear seat area of a 4 door nissan titan. Frequency response was stellar as all frequencies between 38hz and 65hz were all within 2db. Awesome, I'm looking forward to seeing it! Did you use Hornresp for enclosure modeling with this build? If so, would you be willing to share your input parameters? I'd love to take a look at them, though I completely understand if you want to keep that info to yourself (assuming you used Hornresp). "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Hugh G. Rection Posted December 29, 2015 Author Report Posted December 29, 2015 Ill tell you guys what, ill do a couple of vids this weekend on a build im doing. Itll most likely be a 1/4 wave tapered transmission line enclosure, and itll be for 3 skar ix subs on a sk800.1 in an expedition. I tested one of the ix 12s this past weekend in a tapered line on less than 400rms and got it to a 140.1 on the termlab, in the rear seat area of a 4 door nissan titan. Frequency response was stellar as all frequencies between 38hz and 65hz were all within 2db. Awesome, I'm looking forward to seeing it!Did you use Hornresp for enclosure modeling with this build? If so, would you be willing to share your input parameters? I'd love to take a look at them, though I completely understand if you want to keep that info to yourself (assuming you used Hornresp). As you have said, i prefer to keep that to myself. Im very very hesitant to ever give out any specific information on any given build, just because i design so specifically for everything, every build is so specific to the input power, driver, and vehicle. I do use hornresp, in combination with another program. Hornresp has been my main thing for a while now on anything horn or line loaded, and over the years i have developed my own bastardized way of using it, and i take into consideration several factors of the listening environment in doing so. It is a great program, and its a shame not enough people use it. The interface is tough for novices, but for veterans it makes perfect sense. It makes you see just how useless script based calculators like torres really are. Owner of BigAss Ports
Triticum Agricolam Posted December 29, 2015 Report Posted December 29, 2015 As you have said, i prefer to keep that to myself. Im very very hesitant to ever give out any specific information on any given build, just because i design so specifically for everything, every build is so specific to the input power, driver, and vehicle. I do use hornresp, in combination with another program. Hornresp has been my main thing for a while now on anything horn or line loaded, and over the years i have developed my own bastardized way of using it, and i take into consideration several factors of the listening environment in doing so. It is a great program, and its a shame not enough people use it. The interface is tough for novices, but for veterans it makes perfect sense. It makes you see just how useless script based calculators like torres really are. Understood, and I thank you for the information you are willing to share. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Borris The Blade Posted December 29, 2015 Report Posted December 29, 2015 Awesome man, I'm looking forward to it. It's like rubbing your wiener up against a sheep.
