CleanSierra Posted January 15, 2016 Report Posted January 15, 2016 Tuning at Fs will give the most output. Playing below port tuning can risk over excursion. So if I tune a sub with an Fs of 17 Hz, like the Stereo Integrity HST18, I'll get the most output from that sub? Im not the one you want to try to troll. Just a fyi for you.
ShadeTreeMechanic Posted January 15, 2016 Report Posted January 15, 2016 I am getting the feeling that tuning the port at Fs does not give max output? Maybe I was thinking Fb. Can we buy a clue? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
ShadeTreeMechanic Posted January 15, 2016 Report Posted January 15, 2016 It looks like I'm on my own. I will research the correlation between Fs and tuning and report back. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
CleanSierra Posted January 15, 2016 Report Posted January 15, 2016 I am getting the feeling that tuning the port at Fs does not give max output? Maybe I was thinking Fb. Can we buy a clue? Hey, sorry I was at work. I think you had Fb and Fs confused. Fs is just free air resonance. Im not the one you want to try to troll. Just a fyi for you.
reedal Posted January 15, 2016 Report Posted January 15, 2016 I say jump up to the hdc4 and get a 18 if can fit it. The hdc315 has higher sensitivity over the 18.LOL!!!!!!!!!!!!Hmm? I'm having a hard time understanding why you suggested the HDC418 and made the statement about the hdc315 having higher sensitivity than the 18... SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
ShadeTreeMechanic Posted January 15, 2016 Report Posted January 15, 2016 I am getting the feeling that tuning the port at Fs does not give max output? Maybe I was thinking Fb. Can we buy a clue? Hey, sorry I was at work. I think you had Fb and Fs confused. Fs is just free air resonance. Thanks man, I know how it is. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Irocthestreetz Posted January 15, 2016 Report Posted January 15, 2016 I say jump up to the hdc4 and get a 18 if can fit it. The hdc315 has higher sensitivity over the 18.LOL!!!!!!!!!!!!Hmm? I'm having a hard time understanding why you suggested the HDC418 and made the statement about the hdc315 having higher sensitivity than the 18... Sorry that was a bit confusing.what I meant was that if he decided to stick with the hdc3 series that I'd personally go with the 15 due to higher sensitivity over the hdc318.
Triticum Agricolam Posted January 15, 2016 Report Posted January 15, 2016 I bet that sensitivity number is wrong, there is no reason why a 15" sub would be more sensitive than an 18" of the same product series. It doesn't matter anyway. Once you put the sub in a box, that sensitivity number doesn't mean much. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Irocthestreetz Posted January 15, 2016 Report Posted January 15, 2016 I bet that sensitivity number is wrong, there is no reason why a 15" sub would be more sensitive than an 18" of the same product series. It doesn't matter anyway. Once you put the sub in a box, that sensitivity number doesn't mean much. Who knows. I've seen similar specs on other Brands of woofers where the only difference was the cone size. And how does the box effect that?
