MADVIBES Posted January 14, 2016 Report Posted January 14, 2016 If you cut the top piece first you can use this to figure out angles and lengths of the entire enclosure, Much easier than trying to buld the sides of the box first. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Triticum Agricolam Posted January 14, 2016 Report Posted January 14, 2016 Sure, it's possible. It would be a lot of work. You'd have to know exact angles, degrees of each point? Because not all 5 points are equal right? Some, the arms id guess you'd say, are more angled than the rest? On a difficulty scale how hard would this be? Could you produce a cut sheet? Or is the math something out of this world time consuming and hard? It wouldn't be THAT hard. There really are only two angles, the angle at the points, and the angle at the intersections between the points. Just lots of repetitive cuts on the table saw. Probably the hardest part about building it would be clamping it all together while the glue dries. A Kreg jig or brad nailer would make that a lot easier. I would probably layout the port a little differently to simplify things, but there is no reason something like that couldn't be built. My big questions is "why"? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Jessica Posted January 14, 2016 Report Posted January 14, 2016 nice thing is at least you can look up the angles ahead of time then all you need to do is figure out how big to make it. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
gr8handogoatness Posted January 15, 2016 Report Posted January 15, 2016 You could build a square box so that you know how to port and tune it and get the audio side of it right then build a star facia around the box. Bondo,a bunch of sanding and some paint and none will be the wiser. It's possible that there will be some weird resonance but probably some foam or batting or something could fix that.
RyanRosier Posted January 15, 2016 Author Report Posted January 15, 2016 Sure, it's possible. It would be a lot of work.You'd have to know exact angles, degrees of each point? Because not all 5 points are equal right? Some, the arms id guess you'd say, are more angled than the rest? On a difficulty scale how hard would this be? Could you produce a cut sheet? Or is the math something out of this world time consuming and hard?It wouldn't be THAT hard. There really are only two angles, the angle at the points, and the angle at the intersections between the points. Just lots of repetitive cuts on the table saw. Probably the hardest part about building it would be clamping it all together while the glue dries. A Kreg jig or brad nailer would make that a lot easier. I would probably layout the port a little differently to simplify things, but there is no reason something like that couldn't be built. My big questions is "why"? How exactly would you do the port? Slot? Areo? or just a different layout? And same reason anyone else does a build, because why the heck not?!?! lolll But just simply out of pure love for the field of audio. Now how would you be able to calculate the total internal air and the port displacement? 2003 Chevy Silverado Reg Cab. Rockford Fosgate 500a2 and Kicker ZR240 each on their own 12" Kicker Comp S. Small, but everyone's gotta start somewhere.
audiofanaticz Posted January 15, 2016 Report Posted January 15, 2016 I could make this easily, and so that there wouldnt be angled edges for the sides that could be a potential weak point. stack-fab ftw
Triticum Agricolam Posted January 15, 2016 Report Posted January 15, 2016 How exactly would you do the port? Slot? Areo? or just a different layout? And same reason anyone else does a build, because why the heck not?!?! lolll But just simply out of pure love for the field of audio. Now how would you be able to calculate the total internal air and the port displacement? I would do a slot port, much like what you had in the picture, but I would have it exit right below a "point" in the star so you wouldn't have the 90 degree corner at the end. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
mothra Posted January 15, 2016 Report Posted January 15, 2016 I could make this easily, and so that there wouldnt be angled edges for the sides that could be a potential weak point. stack-fab ftw exactly what I was thinking. it would be way to time consuming to cut and join all those edges. by the time you get all the angles figured out and the cut angles figured out, i could be half way done. if nothing changes, nothing changes You don't know what you don't know, till you don't know
3vil Posted January 15, 2016 Report Posted January 15, 2016 I agree with audiofanaticz that layered mdf would be easier, and it would also allow more freedom in the design. You could do more rounded points on the stars to give the final box a smoother look. Everyone who's talking about how hard the math would be needs to go take geometry again though, this isn't that complex of a shape and it's not like you need integral calc to make it all work.
audiofanaticz Posted January 15, 2016 Report Posted January 15, 2016 Plus with stack-fabbing it, you can make the walls whatever thickness you would want and wouldnt be limited to 3/4inch like the wood itself is.
