Ampere Audio AA-9.0 TFHE (Amp Guts)
VomitUrSoul
seeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeex
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Nice looking amp! Why only a single output though? Duals are pretty standard aren't they? No matter, still looks solid!
Speaker outputs stated on the amp, yet there is only one speaker output. Most likely won't do rated power now, but it might be good for the money.
what makes you think it wont do rated? only reason why other amps have 2 outputs its for easy wiring. get a dual 2 ohm sub and wire each input to each output and bam 1 ohm.. same if dual 1 ohm.. will be .5 ohm
Maybe I should have put ha ha..... Man your quick
It'll do rated and then some. Speaker outputs have little to no effect on the power output. Matter of fact, these are larger than most I've seen. I can probably fit 4ga in there.
I wasn't trying to imply it wouldn't do rated with that quesion :)
I was just curios why they didn't use 2 outputs, it seems to be the standard these days. If it can fit 4g then that's my answer!
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
