I don't have any of it cracking. Wasn't expecting it. Was actually headed to work bassing out and boom spider webs everywhere. I was happy and sad lol. I will post some after the new window
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
a friend lost on the meter from doing a pole. It doesnt always gain ya.
What he said....I added a stripper pole everything below 33hz down to 23hz sounded WAY cleaner with WAY more authority but lost around 1.5-2db on the meter sealed up even though it sounded louder.....I did gain door open though
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
Probably will never meter it sealed up. Usaci style in the kick drivers door open is what I built for. So that's fine. If it loses some I'll try to make it up in other ways. Ultimate goal is 63's on music.
Have not metered since it's not sealed off at the b pillar yet. Last build was a 57 and this is a good bit louder and way more pressure.
Anyone else with a pole? What is yours made of? Will be doing it this weekend!!!
I like how Kevosinn(Kevin Fickling of CNF) did his bracing in his van. I like the style that was done in his enclosure. I'm not sure he had a stripper pole but his box bracing is the style I'd prefer.
you could ask the guy with the custom 21" sub in his mazda6. he did a pole after going through like 4 windshields. he may have some tips for you. probably find his build in member builds
