Dd1 on mids and highs?
Myself ive never used the dd1 for setting mids and highs.... Pretty obvious when they sound like shit.. just me.
i personally would never set my mids and highs without a scope or a dd-1. Once you know your limits of course backing down from that limit by ear is acceptable. If i was going to "guess" my gains on any part of my system it would be the subwoofers not the highs. They can take more abuse if you are wrong...and unless you know your starting point, you probably are wrong.
Follow my Tweet (Twitter)
I have a rockford p300x2 running a pair of infinity kappa tweeters that say 50 watt rms and a pair of pioneer ts-D1730C 60 watt rms soon to be sundown sa 6.5csv2 .. with the dd1 currently would I be ok with the -5db track?
it sounds like your amp is slightly too big for those mids/highs. That 300x2 is probably doing 400 watts. Get the proper sized amp or use the -5 to start with and back it down a little bit. I wouldn't use the 0db track. Personally, something like a -2 or -3 overlamp would be perfect for those IMO.
i personally use -2.5 here for my mids
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
thanks steve, I went with a larger amp because I'll be installing the sundown audio sa6.5cs v2 soon as the weather is good, I figured I would be at a good power match up with them.
if you are using the 80prs, just use the "mid" out to set your tweeter amp then plug your "highs" out back up. I set my amp with the 0db and then just used the pioneers menu to cut the output on each tweeter by -5. I have my right tweeter at -7 and my left at -5 to help pull my sound stage back towards center. Your results may vary.
Try it out. Don't go hammering on it right off though. Slowly turn it up after setting with the -5dB and listen for any popping, distorting, smells. Make sure sub-bass is off so you can really concentrate on what the mids and tweets are doing. But all in all, I think you should be good to go.
You may have mentioned it already, but are you doing active or passive?
  • Who's Online   0 Members, 0 Anonymous, 654 Guests (See full list)
