School project help.
I am in a electrical and fluid power systems class at school. We are doing a small group project that has to combine electrical, pneumatic, or hydraulics. Needs to combine 2 of the 3. Small budget of like $75-100. He doesn't want to see another can crusher. Give me some ideas guys. Struggling hard to think of something. Electro-.... Seems easiest but from there we are stumped. Let's see what you guys can come up with. Cheap. Kinda simple.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Build a miniature hydro electric dam that lights a light bulb or a school mascot or something
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Could package it up as soething that you can set in a stream as a portable phone charger or something similar
Or do you need something that has a mechanical function that performs a physical task like moving an object or picking something up?
How would I do the hydro part though? A well expansion tank? Just trying to do something kinda simple and not huge.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Get an emergency tire pump (12v), an air storage tank, a pressure release valve, a pressure transducer, some pvc pipe and a tee, and some marbles.
Make an automatic marble air gun. Pump builds pressure in the tank, when set psi is reached the release valve vents. Valve is located in a horizontal length of pvc pipe with a vertical piece tee'd in. The vertical piece contains a stack of marbles (magazine). Weigh marbles and use physics to calculate theoretical velocity.
EDIT: change marbles to ping pong balls if safety is a concern, like this will be demonstrated inside a class room.
Can do the same thing with a 2 liter bottle, air spot bbs, and an air compressor too.
Vacuum cleaner, hose hooked to exhaust port. Use the air pressure to demonstrate how pressure over area equates to force. Can lift your friend up with a wood board and a few garbage bags underneath it. Or trim said garbage bags and make a hovercraft. Could grab some concrete form tubes and make rudimentary pistons
Could make a heating coil out of some wire, car battery or two, use it to make steam and use the steam pressure to do something. Could grab a piece of PVC pipe and a valve, use it to shoot ping pong balls or something. I'll add that it wouldn't be a bad idea to get a pressure release valve like they use in air compressors so you don't have a bomb on your hands
  • Who's Online   1 Member, 0 Anonymous, 1507 Guests (See full list)
