Pioneer DEH-80PRS USB drive file system limitations?
Anyone know what the filesystem limitations are on the Pioneer DEH-80PRS? I have a 64Gb usb drive with just under 6k songs on it but my current Sony tune tray HU won't recognize all of the songs/folders due to file system limitations. I don't want to upgrade just to have the same problem.
from the 80prs manual
Compressed audio
compatibility (disc, USB, SD)
WMA
File extension: .wma
Bit rate: 48kbps to 320kbps (CBR), 48kbps to
384kbps (VBR)
Sampling frequency: 32 kHz, 44.1 kHz, 48 kHz
Windows Media Audio Professional, Lossless, Voice/
DRM Stream/Stream with video: Not compatible
MP3
File extension: .mp3
Bit rate: 8kbps to 320kbps (CBR), VBR
Sampling frequency: 8kHz to 48kHz (32kHz, 44.1 kHz,
48kHz for emphasis)
Compatible ID3 tag version: 1.0, 1.1, 2.2, 2.3, 2.4 (ID3
tag Version 2.x is given priority over Version 1.x.)
M3u playlist: Not compatible
MP3i (MP3 interactive), mp3 PRO: Not compatible
WAV
File extension: .wav
Quantization bits: 8 and 16 (LPCM), 4 (MS ADPCM)
Sampling frequency: 16kHz to 48kHz (LPCM),
22.05kHz and 44.1kHz (MS ADPCM)
AAC
Compatible format: AAC encoded by iTunes
File extension: .m4a
Sampling frequency: 11.025 kHz to 48 kHz
Transmission rate: 16 kbps to 320 kbps, VBR
Apple Lossless: Not compatible
AAC file bought from the iTunes Store (.m4p file ex-
tension): Not compatible
Supplemental information
Only the first 32 characters can be displayed as a file
name (including the file extension) or a folder name.
This unit may not operate correctly depending on the
application used to encode WMA files.
There may be a slight delay at the start of playback of
audio files embedded with image data or audio files
stored on a USB storage device that has numerous
folder hierarchies
External storage device (USB, SD)
Playable folder hierarchy: up to eight tiers (A practical
hierarchy is less than two tiers).
Playable folders: up to 1500
Playable files: up to 15000
Playback of copyright-protected files: Not compatible
Partitioned external storage device (USB, SD): Only
the first playable partition can be played.
There may be a slight delay when starting playback of
audio files on a USB storage device with numerous
folder hierarchies.
CAUTION
Pioneer accepts no responsibility for data lost
on USB memory/USB portable audio players/
SD memory cards/SDHC memory cards, even
if that data is lost while this unit is used.
Pioneer cannot guarantee compatibility with
all USB mass storage devices and assumes
no responsibility for any loss of data on media
players, smart phones, or other devices while
using this product.
From what I read in other parts of the manual it's fat32 only. I wish it would recognize NTFS or exfat because it's a PITA to format my 64b drive to fat32.
So just to confirm, I got my 80prs the other day and plugged in my 64gb usb drive with all 5479 MP3's consisting of 574 albums (so a ton of sub folders) and everything was there, only took about a minute to read and build an index to. Was able to get a program called "SmartDisk FAT32 tool" to format my drive real quick and easy to.
No they don't work with flac. All I do is convert flac to wav, it's a hassle but it works
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
On my 80prs I plugged in my Fat32 formated USB that I had been using in another Pioneer deck and some hi level folders were not there. Also, after a few days, 2 folders that were there previously disappeared. I dont have anything more than 3 layers deep and the folders that are gone where only 1 layer deep. Just sharing my first hand recent experience.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Is there anything newer that is similar/comparable to the 80PRS in the same price range that will work with FLAC? Also that works better with Android? Not trying to make a versus, just trying to know what's out there.
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
