battery bank wiring help
ordered 2 more xs d3100s from Showtime car audio going 2 have 2 batteries on each side of my port just wondering on how to properly ground the second set of batteries.
My current setup
Option 1
option 2
Do I ground all batteries on same frame rail or one set on each side being that this would give shorter ground path. Don't want to induce noise etc. ty for all your help
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
the difference in length is pretty negligible there so I wouldn't worry about that part. The second way seems like it might end up being cleaner looking, other than that there isn't a huge difference in the two options.
That's what I think anyway
:peepwall:
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Anyone else
Positive is positive and negative is negative. Electrically there is not much difference in your proposed configurations. It mostly depends on what is practical for your installation.
Pioneer 80PRS
So If I don't ground both battery banks to same frame rail this won't give me noise issues this is my only concern because it has shorter ground path
I am far from an expert with this stuff (barely knowledgeable to be honest), but I don't think this is what is meant by a ground loop. I thought a ground loop is when a piece of equipment had multiple ways to ground it self (like the pioneer headunits when the pico fuse blows, it grounds itself through the RCAs instead of the chasis ground). Grounding your batteries in 2 different places wouldn't cause an issue like this.
F150:
Stock :(
Processor: DSR1
Try to keep your frame grounds short (again, not a major issue) and tightly ground them to bare metal of the frame and be done. Spray it with some type of rust protectant (rustoleum enamel for example).
Singer Alternators
Team Asshole
#anothershittysingerbuild
  • Who's Online   0 Members, 0 Anonymous, 860 Guests (See full list)
