sub just stopped working... is it blown ?? someone enlighten me.
Setting your gains with the DD-1 is an excellent way to get a base line on your signal. Different sources for music and different songs from the same source can be recorded at different levels. It is up to the person with the volume control to monitor what is happening in day to day use. You still need to use your ear-o-meter.
Pioneer 80PRS
If the chambers and ports are separate you would be ok. if they have a common port then they need each other to provide proper loading in the port.
Pioneer 80PRS
I have taken it out of box already and listed everything that is visible to me in post. I feels as though what holds the coils down by the magnet has broken and is letting the coil move freely up to the cone. I have never had an issue like this before especially so early on. All my JL audios typically last about 5 years before issues. I feel like this sub may have had some type of factory imperfection .
that sucks that all your subs have issues after 5 years sounds like time to move away from JL if they give issues after only 5 years
  • Who's Online   1 Member, 1 Anonymous, 1572 Guests (See full list)
