Headunit Heat sink insanely hot!
so i just installed my headunit today and already having fucking problems. First I have the tahoe with bose system so with my headunit:http://www.sonicelectronix.com/item_106955_JVC-KW-R925BTS.html i had to buy this adapter:http://www.sonicelectronix.com/item_68044_PAC-RadioPro-RP4-GM11.html that is supposedly supposed to make the 1 ohm bose speakers not burn up my headunit. Got everything wired up together and installed and i can barely turn up the volume without getting insane distortion and my headunit heatsink becoming burning hot within 15 seconds. What the fuck is wrong?
Grab a multimeter and test the resistance pf the speaker leads.
Does that interface have an option for choosing whether you have the non amplified system or amplified (Bose) system? Like a different spot to plug the harness in for either?
I ask because I use the PAC OS-2X in my 03 Tahoe with factory Bose (before I took bose out) and if I plug the vehicle harness into the amplified side like I'm supposed to, it gets distorted really early, even though I know my hi-level speaker outs on the 80prs don't distort until 52/60 via DD-1. But if I plug it into the non standard side, I don't ever get any distortion.
I would call Sonic or maybe the company that made the adapter.
Pioneer 80PRS
That does not change the ohm load your H/U sees, so it will get really hot if the impedance is too low for it.
Pretty much sounds like you'll want to upgrade your speakers from the bose system.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
well i went over to CarToys and had them figure out what the problem was, I missed a few things he said, but he said the wiring was a little jumbled upp which probably caused the over heating.
