Tarball Posted May 17, 2016 Report Share Posted May 17, 2016 Hit up a junk yard and have a spare tranny standing by. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
Deeznutz Posted June 6, 2016 Report Share Posted June 6, 2016 So what did you find out about your transmission? -Frank Link to comment Share on other sites More sharing options...
bones2003gmcz71 Posted August 20, 2016 Report Share Posted August 20, 2016 i have a 2003 gmc z71 with a rebuilt tranny in it, everything was working yesterday, got in it this morning and no shift to third, not slipping just no shift Link to comment Share on other sites More sharing options...
bones2003gmcz71 Posted August 20, 2016 Report Share Posted August 20, 2016 If there is junk stuck in the corners then its better to stay where it is instead of having it clog up the valve body. This is why the flush gets a bad rap. loking for some help with freshly rebuilt 4l60e??? Link to comment Share on other sites More sharing options...
Chase Wallace Posted January 1, 2017 Report Share Posted January 1, 2017 Most transmissions can be built with better clutches and bands to handle more power and torque. With more weight you will essentially have to push the engine harder to get the same acceleration which is applying more torque to the transmission which is shortening the life of it. Keeping the fluid cool will help with the life of the transmission but a performance rebuild that's setup to handle more torque should solve this issues with it. This goes for the OP but also would be my answer to issues with a 4L60E in a Z71. I have a 2000 Chevy Silverado 1500 and really wish it would have come with a 4L80E. A performance rebuild to handle higher torque would be nice and should work just fine at stock HP levels but when my 4L60E goes out I would really like to replace it with a pull out 4L80E from a low mileage 2500HD/3500HD series truck. The 4L80E has a much higher torque complicity stock than the 4L60E and can hold far more torque in a max performance application. Link to comment Share on other sites More sharing options...
deathcards Posted January 4, 2017 Report Share Posted January 4, 2017 sounds like some solenoids went bad skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted January 4, 2017 Report Share Posted January 4, 2017 Fresh rebuild crapping out? The cooler was probably full of junk and not flushed out. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
aculous Posted January 10, 2017 Report Share Posted January 10, 2017 On 8/20/2016 at 2:16 PM, bones2003gmcz71 said: loking for some help with freshly rebuilt 4l60e??? skip the 4L60E because its crap. Upgrade to a 4l80e, and make sure your converter isn't trashed. You can get them pretty cheap from junkyards and they're plentiful. Link to comment Share on other sites More sharing options...
