battery lug rings or "car audio" rings
Battery lug rings
"Car audio" rings
Im adding a second battery in my truck tool box, dont know if there is any pros for using copper battery lug rings over "car audio" rings other than to copper battery lugs are much thicker than the "car audio" rings.... I know alot of people use both styles, care to educate me ?
One's used in industrial applications and UL listed, the other isn't. Lugs are the real deal, those ring terminals are just cheap garbage. They do the job, sure, but when the good stuff doesn't cost much more, just get the good stuff.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
Plus those particular battery lugs are closed end which if heat shrink is properly applied, will protect better against corrosion
Pioneer 80PRS
4 Scan Speak discovery 4" full rage
2 Ampere Audio 6.5 Comp sets
3 Singer 370 Hairpin's
1 Odyssey g78/34-P1500
6 DieHard Platinum Marine g31
4 XS D3100's
DC 175.4
DC 90.4
4 DC 5k's
4 m3 lvl 5 15's
Soundrive RCA's
Lots of welding lead & SkyHigh
Team DC AUDIO
I like the "garbage" ring terminals, I mean I only did a 158.9 with garbage ring terminals and junk CCA wire.
Used to have a loud truck
I like the lugs because it's easier to put together, I don't have any type of press so I cannot really use the other ones to well. The lugs, heat it the fuck up, fill with solder, and bam your done.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Now we all know why you didn't get that 160!
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
You'd have more power to throw at your woofers if you weren't going through thin, high resistance tinned ring terminals and high resistance power wire. My point still stands. You can be totally content with the cheap stuff, that doesn't mean it's just as good though. Buy nice, or buy twice.
Don't mean to offend, i'm using CCA wire, i just acknowledge i'd have more voltage going to my amp with OFC, meaning more voltage across the rail, and more power.
03' Trailblazer LT
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
Copper lugs all day have used both lugs our way better I hydraulic crimp mine.
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   0 Members, 0 Anonymous, 936 Guests (See full list)
