Hi.
Please advice amp/subwoofer for a daily listening system for my SUV and to match front speakers, I probably get only a pair of 6.5 inch, and a pair of tweeter.
Music I listen to are
80% - extreme/death metal lots of kick drum,
10% - pop,jazz
10% - electronic/dubstep/rab/drum and bass.
I aim for SQ, more musical, less distortion, deep, clean, and tight bass.
Option 1: one SD-3 10" in sealed box.
Option 2: two SD-3 10" in sealed box.
Option 3: one SD-3 12" in sealed box. <-- preferred
Option 4: two SD-3 12" in sealed box. <-- probably too much?
Should I get them 4-ohm or 2-ohm version? and which amp?
Please, for any other suggestions.
Pumin
I have a SD-2 10. It's on a RF T5002 at 2ohm. been great
single 10 or 12, on a Sundown SAE-600D. Keep it simple, keep it clean, keep it matching.
Depending on the vehicle one SD-2 12" Dual 2 ohm wired in parallel to bring down to 1 ohm on a SAE-600D would be fine for what you want.
Two SD-2 12" Dual 4 ohm all wired parallel would also see a 1 ohm load on a SAE-1000D and would give you a bit more low end.
Budget and space is what will be the deciding factor.
What they said. Lots of good amps that will get you the right amount of watts. The sd's sound great sealed and on rated power.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Thanks for all suggestions.
If I go for 2 of SD3 subs, should I get 1500-watt amp (eg. SAE-1500D or SCV-1500D) instead of 1000-watt?
If your budget will support it, that is what I would go with. The extra power will help in a sealed box.
I vote the scv
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Fi Audio Q 10s
Big 3
Singer Alternator
Sky High Wire
  • 1 month later...
I have an SD-3 12" D4 in a sealed box just under 1 cu ft. The one I have was the prototype unit that has the machined outer spokes unlike the production models. I have it powered by a RF 501bd and processed with an MS-8. It is an awesome sub but I will be upgrading next year so I may sell this one.
  • Who's Online   0 Members, 0 Anonymous, 1665 Guests (See full list)
