Okay my bro has a 1000W sony amp pushin a 15" L7 wired at 2-ohms with a 4g power and 8g ground. the ground is to the sheetmetal under the carpet in the trunk and it lit on fire twice b4 we had it bolted to the trunk lid and actually scorched the lid!! any help?
Derp.
Why would you use 4g power Then bust out the Speaker wire for a ground....?
Use 4g for the ground aswell!
WWW.OSGINDUSTRIES.COM
I LOVE HATER'S
rule of thumb is to always run the same size ground as the hot going to the amps....
I no longer live by tha sword, I'm living tha good life cuz I live it for the Lord. God is good, all tha time...
agreed.... always use the same size wire..... why would u ground it to the trunk lid???
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
DC.jpgDC POWER
i was wondering the same thing!! those are the problems........use the same size wire and then find a different place to ground it! NOT THE TRUNK LID :wacko:
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
It is the heat from the smaller wire that will cause problems. It tries to keep up with the current flow from the larger power wire and creates heat. I have seen the insulation melt on power wire before but never seen it catch anything on fire, only heard horror stories about people burning up cars from poor install or improper wire/fuse choice.
Bolt the ground to bare metal on the body or frame of the car. If you don't feel confident doing that you can always run the wire directly back to the battery negative post.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Think of it like a push pull kinda situation, the power wire is pulling all the 4 guage current and is trying to dish it out to the ground but if its smaller theres alotta resistance there.
I sometimes even make the ground larger than the power.
  • Who's Online   0 Members, 0 Anonymous, 7441 Guests (See full list)
