Picked up the strictly audio non-daily vehicle this afternoon. The box will be a slide-in 4th order
20 10" midrange
16 Orion HCCA tweeters
2 Taramps HD8000 (mids)
2 Taramps HD800 (tweeters)
1 Singer 350a alt
4 15" Sundown Zv3's
2 Sundown SAZ3500's
2 EA 370a alts 19v for substage
The Jeep itself. She's rough around the edges but I'll take good care of her
2882148F-8A09-4740-BEFE-9B895D398A13_zps
I gutted front the b-pillar back the day I got it. I'll be cutting the roof braces out and doing 2 sheets of 3/4" MDF on the roof. The quarter panels will be completely filled with spray foam with 2" PVC pipes ran down each side to run the wiring
FA8C2C17-4CE4-4C41-A06A-70A8A3E3AC9A_zps
CB8D8B4E-55C9-4634-BDF8-0B3BCA809E84_zps
I was finally able to talk someone into selling me their 4 15" Zv3's. Every time a set popped up for sale, I didn't have the money at that particular moment. Luckily I grabbed them today
F8084528-B6CA-4D6F-ADCC-3D2B4A66A498_zps
373D21D0-9E34-47F4-99BB-8AEA3D5F8864_zps
Just like my Tahoe build log, I'm going to take very detailed pictures of the way I build my front stage because it'll be unlike anything anyone on forums is used to seeing. 16 10's and 16 tweeters in a 2 door... I'm excited for this one
Kerfed some wood and glued it to the roof. I'm kind of worried I didn't use enough glue. Roof is 4x6' and I used 6 tubes total. I'll find out next week if it was enough
Oh and don't mind the crooked lines. I let a buddy do the cuts who's never used a circular saw before lol
C2DE2848-4226-4AAC-ABE7-481B51724E2C_zps
E21A2D57-A497-4657-A906-CBABCC11746E_zps
This isn't as easy as I thought it would be but its getting done
405B4E21-512D-4510-B388-05DBACD76192_zps
7B0E18FC-7060-435C-A408-D905D906E74D_zps
F5C3C5FB-6751-4964-87BB-A7C8A4D1756F_zps
Today was probably the most productive day I've ever had when it comes to car audio stuff. Got about 75% of the box done. Still need loading wall and sub baffle and it's all set
Yes everything is crooked. They were just randomly spaced out until the spacers were inserted and welded up
A66DA3F6-880A-4AF0-A203-6E374239A4AA_zps
DDBD3BBD-8CB1-4C0D-B29E-C30F63E18450_zps
2BD6C841-86E5-45F2-8A7B-7FB3FA3B295E_zps
1FC1A9EB-9CA0-4A9F-B451-B9D81D405AB1_zps
Got started on the doors. Measuring and actually getting things cut end up having 2 very different dimensions. Each front door will get 5 10's and 5 tweeters. I also have to make custom front seats to fit min the remaining area but that'll be the last thing I end up doing
96B2F13E-5F1F-4791-A90C-5E3E1B44A47D_zps
85E4E7A9-FFDD-410A-A7A7-26A293C1C37B_zps
Still unsure of which tweeters I'm going to run so I didn't cut those holes yet
BAC2ECFF-F9E2-41AC-B8DD-71902AF8067A_zps
Forgot to get the bendy plywood so I'll finish the doors on Monday
8BF528F9-BD64-42F8-B540-C9ECDBDEFD5F_zps
F752ACF4-7ACA-4161-AC6D-48E8168DF2DA_zps
Doors are done, for now. Have to decide if I want to paint them or wrap them. Also have to make grills for each door but that can't be done until I know if I'm painting or wrapping
0394B3E5-88C7-48EA-B15D-7DF1B16D01CA_zps
Made my steering wheel today. I was going to have an adapter made but I did what I usually do and hack something together
Adapter plate with all holes drilled
F6E60E04-20A6-40B6-93DF-D9CCB17BFB82_zps
What's left of my stock steering wheel
16D101B4-C243-49C6-B701-4002DA6D9C21_zps
Adapter and stock piece
F1DD323B-03B1-4E1D-8A49-DB30795D676F_zps
All bolted together
6F3D4D6F-8F17-48E9-9FB7-46B63C984DE4_zps
Dust cap to cover the ugliness
A3CC749C-3C0C-4A51-95F9-7F8016A0F57D_zps
And the back side, which is REALLY ugly and weird looking. Good thing no one will ever see it in person
D270781B-DF27-475D-AA32-B0DA5E59A932_zps
I forgot to mention why I made the steering wheel. I made both doors symmetrical based off of the passenger side and didn't think about the steering wheel... well here's the drivers side
DC79FF1A-6D44-49A1-A039-85AFC2A6582B_zps
So I've finally realized I just wing everything and assume it's going to work and usually get extremely lucky. Just like the door panels and the steering wheel. Well I finally cut the sub baffles and took one home to test fit the subs and they are way too close for my liking. Not sure what I'm going to do about this one
FA2882ED-9019-4C8F-B478-689F8E799908_zps
Here's how the rest of the box is shaping up so far. It's been in the 90's for heat with 60%+ humidity so I stopped working on everything all together until a few cooler days roll through then I'll finish the box
13530E40-B404-43F6-85F1-9CBA8A84210E_zps
301137E5-363B-4039-BA5A-CE0A6865DEF5_zps
Haven't done much since the weather won't stop being 90+. I finished the first sub baffle, which was a task getting everything measured up perfectly. The gaps between the subs aren't perfectly symmetrical but they're close enough for me
The grooves for the basket were the tough part. I wanted to make sure there was as much room as possible to run the bolts for the subs
0A96EB4C-CBA4-4DBD-9067-BD4F486F7F4F_zps
D24B2EBC-3AE7-4CFA-AB96-573E0AFC7816_zps
Just threw it into the back of the shell just to see how it looked
CC98DBC8-189A-48CF-A416-FD114FF13BBC_zps
I forgot I had missed some spots on the cage with paint before I started gluing the wood down so I went crazy and painted everything. I think it looks kind of cool
03CA2567-7BA2-46D9-A33A-3BFB189D26D5_zps
Also picked up more copper today. I don't know how the batteries are going to be placed so I just keep buying all the copper I can until I figure out what I'm doing exactly. I'm going to most likely use the large square piece as distribution panels for all the power and grounds
FC0611B7-3E3B-4288-A0F0-363A8F13DB40_zps
wow, very extreme, in for this one!!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Lookin like it should be obscene
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Thanks guys. I'm shooting for a 160 pretty much right out of the gate. There's 2 Cherokee 4th orders that I've studied pretty well. Jared's, which when he ran 4 15" Zv3's was able to do a 162 "legal" with a pair of NS1's and Kevin Futrell's 2 door, which does a 160.x with 4 Zv4's and 4 saz3500's.
Sealed scores are just a base to gauge where the truck should be. Where I compete, you play music with all doors open for 3 1-minute rounds and you're judged on overall sound, which explains the 36 mids & highs
i dig 2 doors. Ran around with a buddy in high school that had a blue two door with a manual tran. We beat that thing like it owed us money. And it just ran and ran. I like the look of them also. I had a white 4 door for 9 years. I put tires and a battery in that (with service) in the entire time i owned it.
Nice work man. Wish ya luck. :hi:
dont see too many 2 door jeeps, especially one thats still solid. Tuned in for this one!
This one is far from solid lol the rockers are pretty bad but the floors are good. I'm constantly on the lookout for a clean 97+ 2 door to replace this one with but they are pretty uncommon
  • Who's Online   0 Members, 0 Anonymous, 1389 Guests (See full list)
