Pro Audio sub using four RF T3-19" drivers
Its not a commercial product, its just a one-off project Ricci made for his business. The price he listed was just what he estimated it would cost as a commercial product. He said he only spent about $6500 on the thing, so he must have got a pretty good deal on the four T3-19"s.
Builds:
Let me know when you're ready to design one of these Tri
Lol, Ricci has a big post on his web board about how he designed it. After he explained he methodology there really isn't that much to the design, its actually pretty simple. I could probably take his idea and run with it pretty easily. However, he went through a LOT of trial and error in various simulation software before he got to something that would work, and he took into consideration factors that I didn't even know existed. Seeing what he did definitely reinforced my belief that when it comes to audio, the more I learn, the less I know.
Builds:
Someone removed part of the OP............??
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I want to hear it, I think pro audio is pretty stagnant and could use some "car" guy ingenuity. It looks neat but I think it lacks port so it would be constrained to indoor venues. Horns and horn-like enclosures I think are the way to go for open-air venues.
Got a link to the build thread?
Here's one me and a friend put together for his company, have about $1K cdn into it total, its not excessively pretty but it gets the job done and seems to not vibrate all over.. ; )
http://www.stevemeadedesigns.com/board/topic/205646-new-toy/
I'm always surprised when I hear this thing play, there's a ton of material that most subs i've just never heard be able to play. For example this song.. lol!
Hammerdown... 1%
Here is the link: http://data-bass.ipbhost.com/index.php?/topic/561-zod-audio-maul-test-results-and-discussion/
I totally agree that horns are where its at for pro-audio (and home audio). I'm trying to find ways to make horns work for car audio as well, its just tough making them fit.
I saw you thread about the PA bass cab you built. It looks pretty neat!
Builds:
I'm thinking of building a horn for my next HT sub. Is there a good article/thread on horns and how to design them that is relatively easy to read that you know of?
Dipole over horn for me.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
The design is pretty simple in its basic form. You divide the speed of sound by the quarter wave length of the desired frequency then roll up the works into the smallest space possible, to make the most basic horn. Unrolled you can also call it a transmission line.
Then you add sealed/ported/infinite rear chambers, taper the line, fill the line, plan your bends so they function as 1/32, 1/16th, and 1/8th wavelength filters...
You can go really deep into how different boxes are made and what sound they will make (w-horns, scoops, rear-loaded, front-loaded, ripole...)
Myself I dont think getting that complicated is useful and i'm working at adding horn loading to more standard (ported) enclosures which is why you see the cab that I made built as it is. The basic box is a ported enclosure with probably a bit excessive port area/volume, but that is coupled to the "horn" mouth to give the port and subs more efficiency in exciting more air in front of the cabinet which is what gives the horn the ability to be "loud" in open air venues and project its output further as well.
I'll be completely honest, the box I built used "shits and giggles" math in what I thought would work together well, though there is some intuitive thought behind it as well based on past experience and reading build logs of other people. Specifically the shits and giggles part is the "horn" mouth. I have each side at 17 degrees. I cant quite remember why I chose that number but to me it seemed to couple with the back end of the port to allow the mouth to load it more and increase the frequency response of the port, something about "7 degrees of separation".. which I think may related to 7 degrees of increase per inch of linear port length. Anyways it seems to work as the enclosure is not peaky at all in the lower frequencies and is extremely smooth and quite a bit easier to design than most horns. It should also work well with pretty much any driver that likes ported enclosures.
Really to me the horn is just the mouth. You can do a lot of fancy stuff before the mouth, but the mouth is the business end ; )
EDIT
And horns have a particular "honk" to them. Grab a long tube and talk into it, you'll figure it out in a hurry lol.
Hammerdown... 1%
Horns can be tricky, there is some really good free modeling software you can use for their development though, HornResp.
Getting something that looks good in HornResp is only half the battle though, then you have to turn those specs into a design, which is referred to as "folding the horn". It can be very difficult. Designing a horn from scratch is enough of a hassle that I've never put forth the effort to do it. I've taken existing designs and modified them to suits my needs plenty of times though.
If you want to build a horn for a HT sub (and they work very well for that application) I would strongly encourage you to use an existing proven design. There are lots to choose from and I'd be happy to point you in the right direction if you want.
Builds:
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
