Which Amp is The Cleanest
Emilio Tizzone
Hi guys
So far i've replaced my stock radio in my 2004 Holden Combo to a pioneer PR-80 Head-unit to start off with,
Replaced the factory door speakers with Hertz HSK-165XL 6.5 components,
Only thing i'm stuck on is a 4 channel Amp which gives the best signal,clarity,power to this setup, have got a couple amps listed below,
could really like suggestions or if there is anything cleaner with more power, thanks
* Crescendo C1100.4
* Arc Audio KS300.2 or KS600.2
* DC Audio 175.4
I have no experience with any of these brands but be careful with this type of thread. Could be considered a VS thread and be removed.
Doesn't really matter which of the three you use, you're not running an active setup with those hertz so you'll be okay with either of the 3. I'd probably steer away from arc though. They aren't the same company they use to be.
Team Bass-Hz
get the nendo or the DC and change the op amps to some HIgh quality Burr-Brown. Currently they run JRC op amps. I noticed a difference when doing mine. semi easy for an amp technician. noticable improvement. IMHO
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
How bought Hertz hdp 4
150x4 @ 4 ohms
Keep it all the same brand
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
If they are brand new then all 3 should be pretty clean right out of the box ;)
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
D'amore engineering makes an amp cleaner than those. I would link it but I'm on mobile and feeling lazy, Google should give you what you need
Edit:
http://damoreengineering.com/collections/audio-amplifiers/products/dual-mono-power-amplifier
wouldnt you want to hear the amp before recommending an amp based on spec sheets?
Edit:http://damoreengineering.com/collections/audio-amplifiers/products/dual-mono-power-amplifier
I'd trust what Tony says about his products 100%,
Doesn't matter anyways because I seriously doubt op is about to drop that kind of money on an amp.
I am not doubting at all what tony says about his amps, I am saying people shouldnt make recomendations about what sounds the cleanest with out actually hearing the products. I have heard plenty of high end home amps in my time and some sound better than others. I wouldnt say get the Mcintosh over the bell canto with out actually hearing both amplifiers, thats all I am saying.
  • Who's Online   2 Members, 0 Anonymous, 1200 Guests (See full list)
