jk13 Posted July 28, 2016 Report Posted July 28, 2016 Are you monitoring the amp lights? Is it going into protect or shutting off entirely? Static drops are my bag.
baron_of_bass Posted July 28, 2016 Report Posted July 28, 2016 Does the LOC have a gain on it? Team Bass-Hz
jessdabest77 Posted July 29, 2016 Author Report Posted July 29, 2016 Amp lights stay normal and gain on LOC have tried up and down
MADVIBES Posted July 29, 2016 Report Posted July 29, 2016 have you tried changing loc's? DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
mothra Posted July 29, 2016 Report Posted July 29, 2016 i can't speak directly to your setup but something that I've learned is that on newer GM Bose setups, the amp has this neat little trick of sending it's signal through the negative side of the terminal. many amps and LOCs have a tendency of seeing this at high volumes and not liking it then turning off. I've done quite a few systems where I used the higher end PAC LOCs and the Kicker ZXSum8 that somehow didn't have issues. either way, this is just to give you some sort of direction of where to go. if nothing changes, nothing changes You don't know what you don't know, till you don't know
jk13 Posted July 29, 2016 Report Posted July 29, 2016 Yes Different brand, or just switching one of them around? I'm not telling you to throw money at the problem without properly identifying the cause, but for future reference when you are at the point of spending $50-60 on three cheap LOCs it makes sense to spend a little more for something like the LC6i. Static drops are my bag.
MADVIBES Posted July 29, 2016 Report Posted July 29, 2016 check your battery voltage on your sub amp when this happens. i wonder if battery drop is playing into it. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
jessdabest77 Posted July 29, 2016 Author Report Posted July 29, 2016 I did check voltage and it read fine but that negative Bose amp wiring does make sense.
MADVIBES Posted July 29, 2016 Report Posted July 29, 2016 actually it doesnt, speaker wire is AC voltage, your loc cant tell positve from negative since they alternate. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
