Krupske Posted August 5, 2016 Report Share Posted August 5, 2016 A noob here... I'm not at this stage yet but... How do i set the amps? Just until i get it at a shop to (fine) tune it. So the gain, frequency, punch eq and lpf/apf/hpf 1) T400.4 - front ch = tweets @ 4kHz - 20kHz - rear ch = full ranges @ 100Hz - 20kHz 2) T400.2 - midranges @ 160Hz - 5kHz 3) T400.2 - midbass @ 40Hz - 170Hz 4) T2500.1 - subs @ 50Hz and below Thanks! Link to comment Share on other sites More sharing options...
ckeeler11 Posted August 5, 2016 Report Share Posted August 5, 2016 http://www.thesuicidaleggroll.com/gain.htm Link to comment Share on other sites More sharing options...
Wehan Posted August 5, 2016 Report Share Posted August 5, 2016 http://www.wccaraudio.com/smd-dd-1-and-cc-1-combo-pack.html These two tools will replace whatever the shop you were thinking about taking it to and you get to use them the rest of your life for a one time purchase, also seeing as you are in The Netherlands and the only DD-1 on the tool map in Europe is just outside Paris you might be able to rent them out and make a little bit of your money back. Link to comment Share on other sites More sharing options...
Krupske Posted August 5, 2016 Author Report Share Posted August 5, 2016 http://www.thesuicidaleggroll.com/gain.htm Thanks! http://www.wccaraudio.com/smd-dd-1-and-cc-1-combo-pack.html These two tools will replace whatever the shop you were thinking about taking it to and you get to use them the rest of your life for a one time purchase, also seeing as you are in The Netherlands and the only DD-1 on the tool map in Europe is just outside Paris you might be able to rent them out and make a little bit of your money back. Thanks for the tip! But what is the tool map? The downside from ordering from the US is the shipping cost and tax... Link to comment Share on other sites More sharing options...
3vil Posted August 5, 2016 Report Share Posted August 5, 2016 Order 100, then become a European distributor. Link to comment Share on other sites More sharing options...
Krupske Posted August 5, 2016 Author Report Share Posted August 5, 2016 Order 100, then become a European distributor. Wish i had that kind of money... But i don't Link to comment Share on other sites More sharing options...
ToNasty Posted August 6, 2016 Report Share Posted August 6, 2016 I also,don't think that t400.4 can be crossed that high on the amp. Hopefully your hu can ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
Krupske Posted August 6, 2016 Author Report Share Posted August 6, 2016 I also,don't think that t400.4 can be crossed that high on the amp. Hopefully your hu can Now that you mentioned it, i think the max. is 500Hz And if the hu can't either, what then? Use a passive crossover? Link to comment Share on other sites More sharing options...
Krupske Posted August 6, 2016 Author Report Share Posted August 6, 2016 Another question i have is; can the rockford t2500's operate on a 16volts system? Link to comment Share on other sites More sharing options...
