Why did this happen
That is what happens when a connection gets loose and heats up from the extreme resistance.
This is why i prefer to use lugs on the wire and have them bolted to the fuse, with the lugs being crimped.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Skulls is 100% right , that's exactly what happens with a loose connection
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
I've seen this at work before , people install aftermarket stuff and they power it by ramming a wire into the fuse box and when what ever they powered goes bad they pull the wire out and then the fuse gets loose and burns up
The reason this occurs under the hood is from the engine rocking back and forth which over time will loosed the connection when you use the fuse holders with set screws. Some people will check them from time to time and tighten them so they don't have the problem that happened here, but i will not ever use those fuse holders under the hood of my car ever again, as it did the very same thing to me.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Yea that's my fuse block from my alt to my battery. My truck literally runs for 8 hours a day and a lot of the time the alt is doing work. I drive a lot on he freeway and I like loud music
Where do you normally have that screwed down to?
  • Who's Online   0 Members, 0 Anonymous, 953 Guests (See full list)
