Orion Hcca 5000.1 on 4 12" Dc Lvl 2's
Will this be the ideal setup for my amplifier since it puts out anywhere from 2,400 to 3,000 rms on 1 ohm? If I put these subs in a ported box tuned to specs would they be a low end monster or a spl set up? I'm trying to see what exactly I'd be getting since I've never owned DC subwoofers. I know I have posted here in the past but people told me useful info and I've decided to try a different route than before. Plz let me know if these will wang with the 1.25 cu ft per sub recommended or what...
That's more amp then you will need assuming the subs are wired to 1 ohm.. You can still use it, just go easy with the gain knob, they are rated for 600rms. These subs can play whatever you would like (high or low) depending on how you build the box. I've seen them succeed at both in many different applications. My DC's are in a box tuned to 36hz at the manufacturer's recommended net volume. From all of the testing that I have done, this provided the most balanced and musical results for a full range of high and low notes. If your goal is different, adjust accordingly. Hopefully that is a good starting point for you.
08' Grand Cherokee
(2) DC Lvl 4 12's
I have the same goal as far as low and high notes. Just wanted to know if they could take the amp or would I be better off getting 4 12" subwoofers with a little higher of an rms.
I would wire it to 4 ohm if you are really worried about it. Me personally,i would do 1 ohm and fly by the seat of my pants. But that's just me.
Pioneer 80PRS
Am I missing something? 4 600rms subs (2400 total) on 2400-3000 watts RMS? So at most 750rms each sub? That should be fine.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
