RooTxBeeR Posted August 9, 2016 Report Share Posted August 9, 2016 Does the front battery show same voltage as the amps in the back? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 9, 2016 Report Share Posted August 9, 2016 Does the front battery show same voltage as the amps in the back? good hell, it better with all that wire..... dude has more runs with one alt than i did with 2 SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
RooTxBeeR Posted August 9, 2016 Report Share Posted August 9, 2016 Does the front battery show same voltage as the amps in the back? good hell, it better with all that wire..... dude has more runs with one alt than i did with 2 Could be a hick up somewhere maybe. Just checking lmfao, but yes, with all that wire, resistance should be no worry at all. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Jessica Posted August 9, 2016 Report Share Posted August 9, 2016 try clamping at the wire going to the amp, see what you get there. Get an idea of what the amp is pulling. Also, is your clamp capable of doing proper DC clamping? Some cheaper ones dont do so well. on a side note, the 240 S series does about 140a idle and 225 ish hot. At least mine was rated at that. So if you are getting belt slip on a year old belt 160 might be about right. just spit balling here Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
audiofanaticz Posted August 9, 2016 Report Share Posted August 9, 2016 With all that battery reserve you will not get a realistic clamp reading. Your batteries are acting as a buffer to the drain on the electrical system, so you wont be anywhere near in the ball park of the alternators claimed power. That is unless you deplete your battery reserve by drawing more power than the batteries can support, or disconnect a couple batteries so that only one is being used. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 9, 2016 Report Share Posted August 9, 2016 What's the voltage at the alt when clamped? Might have a bad diode in the rectifier. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Mr DeeBeez Posted August 9, 2016 Author Report Share Posted August 9, 2016 I will try the suggestions tonight with him and see if that narrows down the issue. Thank you guys for your in put Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2) Link to comment Share on other sites More sharing options...
Mr DeeBeez Posted August 9, 2016 Author Report Share Posted August 9, 2016 Well he ended up selling his subs today and will be upgrading to HDC4's. So once those are in and playing we will put a load on and test them out. Thank you for your responses. Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2) Link to comment Share on other sites More sharing options...
