DSS ethos 18 help!
sbg
Yep going to check today, the box has about a gal of fiberglass resin inside over all parts.from the put side the don't don't flex at all
Resin by itself (without fiberglass cloth) will make your box nice and sealed up but it adds almost no strength.
Do you have any pictures of the box?
Builds:
if its bottoming around tuning, something is wrong. They should move least around there. Do you have torn suspention/spider??
EDIT - id also triple check your actually tuned at where you think you are...... give tricum your enclosure and port dims and let him do his magic. Maybe your tuned in the 40's or some silly shit. Good luck OP
Curious what the solution is when you find it, tuned in for that.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Just took a look at the box in side and out. Played the sub hard as it could with out making the sounds. Nothing on the box is flexing at all. And everything inside is hard as a rock. Here are some pics of the box.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
O and it's not just at tuning I can Basicly do it all the time
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
is 6 cu. ft. really to big?
The ethos were designed for really small enclosures
Clarion cz702
Ssa evil mids and tweeters
ppi 900.4
2 zcon 18s
Taramps 10k
3 big dekas 1 xs
3 runs of 4/0 and big 3
300+ amp ohio generator
155.7 on dash at 36 (peak) 152 at 25
Just swapped the sub over to my FI box. It got a bit louder and now does not,bottom out as easy. But still does sometimes. Thinking for my power it needs to be in like 4 cuft. I free air the sub. And could get it to bottom out at like 1/8 of my bass knob
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 447 Guests (See full list)
