Ahmed Johnson Posted August 24, 2016 Report Share Posted August 24, 2016 is 6 cu. ft. really to big? Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted August 24, 2016 Report Share Posted August 24, 2016 Yep going to check today, the box has about a gal of fiberglass resin inside over all parts.from the put side the don't don't flex at all Resin by itself (without fiberglass cloth) will make your box nice and sealed up but it adds almost no strength. Do you have any pictures of the box? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 24, 2016 Report Share Posted August 24, 2016 if its bottoming around tuning, something is wrong. They should move least around there. Do you have torn suspention/spider?? EDIT - id also triple check your actually tuned at where you think you are...... give tricum your enclosure and port dims and let him do his magic. Maybe your tuned in the 40's or some silly shit. Good luck OP SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Karkov Posted August 24, 2016 Report Share Posted August 24, 2016 Curious what the solution is when you find it, tuned in for that. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0 Link to comment Share on other sites More sharing options...
sbg Posted August 24, 2016 Author Report Share Posted August 24, 2016 Yep going to check today, the box has about a gal of fiberglass resin inside over all parts.from the put side the don't don't flex at allResin by itself (without fiberglass cloth) will make your box nice and sealed up but it adds almost no strength. Do you have any pictures of the box? Just took a look at the box in side and out. Played the sub hard as it could with out making the sounds. Nothing on the box is flexing at all. And everything inside is hard as a rock. Here are some pics of the box. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted August 24, 2016 Author Report Share Posted August 24, 2016 O and it's not just at tuning I can Basicly do it all the time 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
frogcase2002 Posted August 24, 2016 Report Share Posted August 24, 2016 is 6 cu. ft. really to big? The ethos were designed for really small enclosures Clarion cz702 Ssa evil mids and tweeters ppi 900.4 2 zcon 18s Taramps 10k 3 big dekas 1 xs 3 runs of 4/0 and big 3 300+ amp ohio generator 155.7 on dash at 36 (peak) 152 at 25 Link to comment Share on other sites More sharing options...
3vil Posted August 24, 2016 Report Share Posted August 24, 2016 Can you test the enclosure+sub outside of the car? Maybe it's not the speaker but something on the car that you're hearing? Link to comment Share on other sites More sharing options...
frogcase2002 Posted August 25, 2016 Report Share Posted August 25, 2016 I would forsure turn your ssf up a little . Clarion cz702 Ssa evil mids and tweeters ppi 900.4 2 zcon 18s Taramps 10k 3 big dekas 1 xs 3 runs of 4/0 and big 3 300+ amp ohio generator 155.7 on dash at 36 (peak) 152 at 25 Link to comment Share on other sites More sharing options...
sbg Posted August 25, 2016 Author Report Share Posted August 25, 2016 Just swapped the sub over to my FI box. It got a bit louder and now does not,bottom out as easy. But still does sometimes. Thinking for my power it needs to be in like 4 cuft. I free air the sub. And could get it to bottom out at like 1/8 of my bass knob 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
