Shawn Rockwell Posted September 8, 2016 Report Posted September 8, 2016 Is it OK to put a dual one ohm crescendo contralto 18 and a dual 4 ohm of same speaker in one box? Amp will be a cresendo bc2000d and two of them strapped when I can get it. Reason for doing is i have one dual 1 ohm and cannot find another one only the dual 4 ohm are available
Broke_Audio_Addict Posted September 8, 2016 Report Posted September 8, 2016 Not a good idea. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Wasteland_Audio Posted September 8, 2016 Report Posted September 8, 2016 No, no, and no. They will destroy each other because no matter what you do they will be seeing different amounts of power at any given time. I know this from experience.
ShadeTreeMechanic Posted September 8, 2016 Report Posted September 8, 2016 In parallel the 1ohm will get most of the power and in the same box the 4 ohm won't be able to provide enough back pressure for the 1 ohm. This will cause the 1 ohm to unload and try to make the 4 ohm act like a passive radiator. Just get two 4 ohms. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
ShadeTreeMechanic Posted September 8, 2016 Report Posted September 8, 2016 Back in the day I ran an 8 ohm and a 4 ohm. When the 4 ohm finally blew, it became the passive radiator. Lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Jessica Posted September 8, 2016 Report Posted September 8, 2016 i think if you wired each to 2ohm and then ran separate amps and gain matched you might be alright. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Broke_Audio_Addict Posted September 8, 2016 Report Posted September 8, 2016 i think if you wired each to 2ohm and then ran separate amps and gain matched you might be alright. The t/s parameter's will be different on the two sub's. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
SkarredSierra Posted September 8, 2016 Report Posted September 8, 2016 Just get a dual 4 recone for the dual 1
Triticum Agricolam Posted September 8, 2016 Report Posted September 8, 2016 i think if you wired each to 2ohm and then ran separate amps and gain matched you might be alright. The t/s parameter's will be different on the two sub's. Yup "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Joe X Posted September 8, 2016 Report Posted September 8, 2016 Is it OK to put a dual one ohm crescendo contralto 18 and a dual 4 ohm of same speaker in one box? Amp will be a cresendo bc2000d and two of them strapped when I can get it. Reason for doing is i have one dual 1 ohm and cannot find another one only the dual 4 ohm are available I assume you intend to wire the dual 4 in parallel and the dual 1 in series and then those two in parallel for a 1 ohm final load, I don't think so, you could maybe run a separate chambers box and one amp to each side wired independently and then gain match, you would get some issues but likely not as serious, I would just go for two of the same kind and avoid wasting time trying to solve potential issues.
